Rear end swing when hitting bumps
Jay Dubs
CT
I have a 2018 XLT Max. I've noticed recently that when I hit a bump like manhole cover or something kind of jarring that the rear end sort of swings out in a way it didn't used to do. This is when the rear tire hits it not the front. The vehicle has 60k miles on it. The front struts have also been replaced due to leaks one at 20k and one about 2k ago. I don't see any leaks on the rear suspension and I'm not entirely sure if that's the source of this annoying roll. Any ideas what the issue may be?
Zig10
Mid Atlantic
Check the end-links and make sure you don't have one that is either worn or broken. The factory links are pretty cheap.
J
Jay Dubs
CT
Are the rears on the XLT shocks or struts. The front was covered by the ESP but if the rear is shocks those may not be.
Squark
NC
My dealer told me the rears are shocks and not covered by the ESP. I confirmed they're called shocks in the Ford parts catalog. They're coil-overs just like the fronts, but apparently only the fronts are struts. After 7 leaking shocks/struts I gave up and replaced them all with Bilsteins.
duneslider
Utah
Most likely this issue is shocks, my jeep did this big time and went away after new shocks. It could also be a weak sway bar. Many complain about the stock sway bar and I haven't noticed an issue but that might be because I moved to bilsteins, which made a big difference in the feel of the expedition.
Timmaaay4
Do you have this in writing, that you can share. My dealer is telling my that fronts are not covered under esp warranty
J
Jay Dubs
CT
I don't have this in writing but I do know my fronts were done under the ESP recently.
Squark
NC
This must have changed recently. I just pulled up the brochure from Flood Ford: https://floodfordesp.com/pdf/PremiumCARE_Ford_ESP.pdf
Under the "front and rear suspension" section there's no mention of struts. But in the copy I saved when I got my ESP a couple of years ago, it says "MacPherson Style Struts" in that section.
Aren't the rears designed the same as the front?
They look very similar and are both coil-overs.
LazSlate
Arizona
Shocks. Bad shocks will rebound to quickly causing loss of traction and jarring.
Its not sway bars as those control roll and linkage and parts you would hear noises and notice crappy handling all the time. You can jump up and down on your rear bumper then jump off. The oscillations should stop immediately.
mr_dave
MN
Fronts and rears are both definitely struts, by definition. Whether or not Ford wants to honor the wording in their contract is a different issue.
The behavior you describe is mostly likely caused by a bad strut on the rear. I've experienced this on several vehicles and fixed most of them with new shocks/struts. However, one vehicle actually had a bad spring in the rear which also needed to be replaced, so it could be that too. Or even a broken (or very loose) part of the rear suspension.
