‘08 5.4 fuel pressure regulator hose?
mkbruin
Indy
Looking under the hood today I noticed the vacuum line going to the fuel pressure regulator is split at the back near the firewall.
Does anyone have the part number for this line? How difficult to replace?
Hamfisted
Ft Lauderdale
Are you losing any fuel there ? 'Cause the outer skin is just insolation and you can push it back together if you want.
M
mkbruin
Indy
not sure if I’m leaking or not… but I KNOW I have some vacuum leaks.
Hamfisted
Ft Lauderdale
Oh ok. That line in your pic is not a vacuum line. It's the high pressure fuel line to the fuel rail. You'd know if you had a fuel leak from there. Do you have a smoke test machine ?
Smoke Test Machine at Amazon
