New 2022. My experience. No engine cover?
balthisar
SE Michigan
Part number for max ends in 600B
Thank you! Google brought me immediately to the correct page on Ford's site. I have no idea why I couldn't find it manually. Now hopefully my dealer has it in stock, because apparently I can't spend my points on the site. Sigh.
O
osoms
Clearwater Florida
So the the verdict is in. The dealer road forced balanced the tires and 3 could not be balanced. So they ordered 4 new tires after getting an ok from FMC. They ordered 4 because the 22 inch General Grappers in that design have been discontinued. I assume the tires had bad flat spots from sitting for 3 months waiting for chips. I also ordered a cover on ebay for a 2020 expedition OEM ford part around 100 dollars. Waiting to get that on. Will keep you posted on the ride and cover.
rd618
new york
Did the new tires fix the vibration? Mine is not perfect yet, and I’m on my second set also.
O
osoms
Clearwater Florida
Its in the shop as i write this will know today. Taking off on a 200 mile road trip tonight. Will post the results. Also recieved my engine cover 2021. Part number JL 1Z 6A949 A from Ford. It won't seat because of some A/C stuff? on the left side? Did they re route something and actually change the engine form 2021 to 2022? Online this engine part # cover lists to 2022, but I dont think so. Maybe its me...but it just wont go down. Anyone else have any feed back on this?? And didn't come with the lock down nuts either...separate part #.
dhenderz
I also tried installing an engine cover, in my case the Ford performance cover. It does not fit either. They have added a bracket with hoses/wiring over the top of the throttle body and also re-routed some of the other hoses/lines on top of the engine along the passenger side. I have the SPP and I cannot see how any of the original engine covers will fit. I even tried trimming the cover to clear the bracket above the throttle body. Still won't fit. Gave the cover to my son who has a 2020 F150. Fit without issue.
O
osoms
Clearwater Florida
Yep, Ford gets one banana for no engine cover on the 2022 expedition! Going to return my cover. As for the flat spot tires, drove 200 miles on the new and very smooth. Moral of the story, if your new Ford sits for almost 4 months in Kentucky in the winter months waiting for chips and you drive it off the lot and there is so much vibration in the steering wheel and seats, you most likey know from this thread that your tires have flat spots. The new General Grapper that replaced the discontinued OEM that came with the car has more thread thickness and a more aggressive tread pattern. Problem solved. I am sure in the deep bowels of Ford in Detroit, they know this may be the tip of the ice berg until they can get cars to the dealer in 6 weeks like pre covid. Getting back to the cover, while waiting for the tires at the dealership yesterday, I kill time talking to service advsiors, parts mgr and a salesman....no cover on a expedition I ask, whats up? all said first time they are hearing of it..really?? Tow the company line. Maybe some vendor will see a profit for the 2022 expedtion line and make a cover that fits. Mine has the gray clips and tie down screws on the engine. like there was a cover planned but for some reason Ford just didn't let it happen.
dhronchek
Georgia
Hey so I have 500 miles on my 2022 and tires have the flat spots. Dealer asked me to go 1000 before they would do anything. Any advise in dealing with the dealership?
Bmac1955
Southern Cali
I might suggest anyone that before signing on the line to roadtest the vehicle doesnt have any vibrations. Surely they will likely solve that problem very quickly.
rd618
new york
500 or 1000 makes no difference. Dealer is lazy. Road force test them.if they fail get new ones. But after 12 months or 12k miles they will tell you too bad.
rd618
new york
a good dealer will solve it regardless.
O
osoms
Clearwater Florida
They told me the same. I have purchased 7 Fords over the last 20 years....all i said to my salesman and service advisor...this ain't your mother's flat spots ....com'on man its tires not the engine . Call Ford customer service. Tires are a charge back to the dealer if the flat spots are determined to have happened on the car lot...like in the old days. Ford replaced 3 of mine and the dealer had to buy the forth...thats how it works....and of course there is paper work...
balthisar
SE Michigan
Are any of these happening on the dealer lots, though? We're picking up our orders as soon as they come in.
O
osoms
Clearwater Florida
Ford is still using the old pre covid/ chip shortage policy which isn't fair to the dealer...I was told the old pre covid policy was to make dealers responsible for moving their inventory on the lot. As I said in a previous post on this thread, this is just the tip of the ice berg for FMC until the shortage of chips resolves. Mine sat almost 4 months in the winter in Kentucky. My last retail order for a 2016 Ford Explorer platinium was 5 % below invioce and took 6 weeks to get it. We all remember those days....hoping to see those days again. Maybe throw in 0 % financing... LOL!!!
rd618
new york
So I talked to a buddy of mine who’s a mechanic (big rig, certified up and down for things I have no clue required it), he said tires getting flat spots for sitting is common but they should roll out in a hundred miles or so esp at highway speed. He said even sitting 6-8 months it’s not common to get “permanent” flat spots. he surmised the issue is cheap rubber compound. He has his share of fords, and said they also inflate tires to the max for storage to prevent flat spots. So seeing them happen now he thinks is more on the vendor. He also suggested investing in better quality, his words “it’s the only 4 places your vehicle touches the road”.
O
osoms
Clearwater Florida
Your friend may be correct...new General tires has solved my problem. Will research the next set of tires when the time comes.
Redwater
Manitoba
I tried to install engine cover from Expedition 2021 (Ford Performance cover) to Expedition Timberline but it didn’t fit.
I still find a engine cover for timberline. If someone know please share.
Thank you.
rd618
new york
Thank you.
They don’t make one.
rallyhard
Spokane, WA
Thank you.
Oh, no! My new Ford Performance engine cover part number KR7Z6A949A just came in at the dealer today. It sounds like it’s not going to fit our 2022 Timberline. I guess I’ll cancel the order if there’s no way to make it work on a 2022.
Has anybody found a way to make a cover work on their 2022?
