Anyone know how or where I can get this piece?
Molaf
Merica
On my Expy, the grey locking lever is missing from the female end of the fog light/park aid harness. Dealer says only way to get one is to buy the whole harness… for $300 .
I’ve checked eBay but so far got nothing. Before I got the zip tie route, anyone know if sourcing just the lever is possible?
M
Molaf
Merica
U pick yards around here don't have late model F-150's or Expeditions so I doubt a place like LKQ would sell me just that part since it's part of the harness.
Rob6805
I don't see what is missing. Can you circle it on the picture?
M
Molaf
Merica
Look across the model of the brown portion. There is a grey locking bar over it. That's whats missing on mine. The pic was just for reference(not my expy) showing what i need.
kjtully
Monument, Colorado
The first question is how often does that connector need to be disconnected. If the answer is rare to never then I would suggest a zip tie. This is a part that appears to be under the carriage and out of sight, so the fix doesn't need to be pretty. But, that's just me.
M
Molaf
Merica
I’m with you just seeing if one is available. Otherwise, zip tie route it’ll be if I can’t find one.
Rob6805
Ah, the lever lock is gone? How did that happen? OE's only use those on connectors with lots of pins to ensure a positive connection. They add a lot of cost to the harness. In order to replace only the lever part you'd have to know the mfg of the connector. Tyco maybe? BUT... As other have said, a zip tie or two should do the trick.
M
Molaf
Merica
Vehicle was in an accident.
NukeLife
Charlotte
Yeah you’d have to source it from the manufacturer. That multi pin connector will have the manufacturer information stamped on it, along with the model number.
Probably have to buy the whole connector housing to get the locking lever, but that’s a heck of a lot cheaper than a harness. I’d probably try that route if it were mine—just for peace of mind.
M
Molaf
Merica
Its buried too far down to see who the MFG is. Anyone know who makes these connectors? Only other option is to remove the one from my buddies expy and see if I can 3d print it.
ETA: I was able to take a pic of another similar looking connector in the engine bay. The manufacturer is WDP - Western Diversified Plastics. Think this is the same locking arm that I need. Only bad part is this particular vendor requires a minimum purchases of $100!
And these guys require a minimum purchase of 30 pieces!
