Odd tire? Really on a new 2022 Exp!
Kahuna
San Diego
Just discovered that the spare on my new 2022 exp max stealth has a spare that doesn’t match the set of running tires! What’s up with that??
This vehicle is brand new with 6k miles on it.
Anyone have this experience?
Did you take it back to the dealer and demand a match?
I have four 225/45 R22 Grabbers and my spare is a Crosswind A/T 275/65 R18.
If I have to change a flat this spare is going to make a heck of a rattle heading down the street with the other 3 Grabbers running.
Aspen03
Indianapolis
If it were the same diameter as the other tires I probably wouldn't fuss but off the top of my head that tire is probably a couple inches taller than the existing. 4wd may not be too happy about that. Granted we have a 03's but my spares are the correct size on our navigator and expedition.
Kahuna
Kahuna
San Diego
I just put a call into the sales manager from the dealer that I purchased the vehicle from and he didn’t have an answer for me and frankly had never heard this one before. But he said if I measure the tire overall dimensions with the ones that I’m running I would probably find that they are roughly the same. And not to worry if I have to use them because these tires are only intended to get you off the road not use on a regular basis. He suspects that the production line put these particular spare tires on all of the expeditions and 150s
I ordered and purchased a new 2015 Ford Expedition Limited 4x4 - which came standard with 20-inch wheels and tires (22-inch were optional).
After purchase, I checked the spare tire (not inflated correctly). It was an 18-inch steel wheel, with a different brand tire than the 20-inch tires.
I contacted my salesperson who initially said that the wrong spare was installed at the factory, and he would check further.
After a week, the salesperson contacted me and said the 18-inch spare was standard and would work with the 20-inch tires and wheels that were also standard. The vehicle’s window sticker stated the vehicle had a full-size spare.
I still do not think that the 18-inch spare is “full-size” when the vehicle has 20-inch wheels and tires standard.
GixxerJasen
DFW TX
As long as the overall diameter is the same what difference does it make how big the wheel is? It's just to get you to a tire shop to get things fixed. Only issues you'll run into is if the overall diameter of the tire is vastly different from what you are running. They aren't going to stuff another expensive wheel and tire under there.
LazSlate
Arizona
Did you read it wrong? 225? Thats a 9" wide tire. Pretty small.
rd618
new york
The outer diameter of the tire is what matters. Not the wheel size. So long as the outer circumference is within 1” of the normal wheel everything will operate as it should.
MTB2022
livonia Michigan
I have a 2022 xlt with optional 20 inch wheels and tires. Spare is a steel wheel with 18" tire. It doesn't matter as long as the outside diameter is the same. If you ever noticed the sidewall height goes down as the rim size goes up. 18,20 and 22 wheel/tires all end up with approximately the same rolling diameter. This facilitates speedo calibration and rear axle gearing and power train programming.
Skud
OH
My Stealth Performance is exactly the same. Four 22” General Grabbers and an 18” Crosswind A/T spare.
AJ82
2022 XLT 202A with Special Edition:
275/55R20 Toyo Open Country H/T-D with 265/70R17 Goodyear Wrangler Fortitude HT spare
Kahuna
Kahuna
San Diego
Got it - yes on all accounts. I had a typo on the 4 running tires and thanks to you all I now know the spare is doable if I need it :)
Deadman
Its a spare tire, its made to get you home, not to be match/pretty. You should then complain that its on a steel wheel instead of a matching wheel........
Soliyou
OK
I agree with these statements. However, even if you buy the same size tires but from different manufacturers, the outside diameter will be different.
Accordingly, it is always advisable to use the spare on the non-driving axle. So if you have a flat in the rear, put a front tire in place of the flat and put the spare on the front axle (disengage the 4WD). This is especially important if you are towing or going to drive a long distance on the highway.
Deadman
So how do you do this on the side of the road with the one crppy jack in the car? lol. I know what you are saying, but we usually never have a spare jack when the tire goes down...
Soliyou
OK
You can ask the road side assistance folks to do that for you. Or you have to do it twice. Put the spare on the front location, then put the front on the rear.
Again, no need to do it under normal situations (short distance), but you will hear the rear differential whine pretty loudly with the spare.
Deadman
Roadside Assistance? lol. I live in the middle of nowhere, they would get here 3 hours after I swapped the spare on and went on with my life!
TDBDLB
Atlanta
not good on AWD/4WD.
No members online now.
rockinghranch
