Show your Lifted 3rd Gens
75Flh
LV
May be stock wheels, but Raptors come with different tires... Bigger. As I recall 315/70r17. Effective 35" tires. (34.5" anyway). I'm running 35"s in my Raptor now.
I know, I put smaller tires on...since I did not have the lift I did not want to run the 35.s
Speedboosted
PNW
Here's my rig! New to Forum just got a few months ago and put all black Helo 22" wheels on it with 305/45R22 TOYO Open Country AT's on it and dipped everything else accept door handles. Debating lift or level but currently has no rub. Might add light bar or pod lights next and remove resonator and side exit exhaust but first have to replace brake pads and spark plugs.
This looks nice, I've been thinking about blacking out the grille as well (black '17 EL). Do you have any more photos of it?
willalex09
NOVA
2015 Platinum EL with CCD, readylift 3/2 spacers, 22" BR wheels, and 34" Nitto Recon tires. No ruling or anything at full turn. Wish the rear end was higher but don't think I'm going to be able to get any higher without replacing the CCD suspension.
Adam T
Arizona
1.5" Ranchero Quick Lift (front) and Strut Masters Air Suspension Conversion with 1.5" spacer lift (rear). Can't say it rides better than the air suspension but I got the extra lift I wanted and I think I can go a little bigger on the tires (275 60 20) when I'm ready....
ahopper89
Tucson, AZ
2016 platinum el with 3”front 2” rear level, 2014 raptor wheels and 315/70/17 falken at3 tires 34.5”x12.4”. barely rubs the sway bar at full lock.
ahopper89
Tucson, AZ
i was able to keep the factory active suspension shock, re drilled the upper shock/strut mount location
2015owner2015
Northern California
Bilstein 5100, ReadyLift, Cooper Discoverer Rugged Trek All-Season LT275/70R18 125Q 33" Tires
