jered
ok, sorry i dont know the correct term, it has electric suspension, 3 modes to choose, sport normal and comfort. Can i still lift it?
sorry, it has electronic suspension control. can I lift it?
Right on the $$. Next tire I need tires I’ll be dropping the spacers and going somewhere between +10 and +18
285/75/17 should fit no problem if it’s a +44 offset. If you want the look I have you’ll need 1.25” spacers or a +12 offset wheel. I went the spacer route until my wheels become ****** and I’m tired of how they look. Anything more negative than +12 will require quite a bit of trimming. I had to trim 1” of the front bumper and move my electronic running boards back to fit the 35/11.50/20 +44s with 1.25” spacer. (Which would equate to a 35/11.50/20 on +12s)I saw you have 11.5 wide tires, do you know if 12.5 will fit? I am trying to figure out how wide I can go, or should go. I know 11.5 limits your wheel selection. I was thinking of maybe going 285-75-17, what do you think?
If I put 12.50 wides on I would have a lot more cutting and rubbing to deal with. Would rub all over the front bumper, inner wheel liners, UCAs and running boards with setup i have nowWe are on the same page. I am just wondering if you could fit 35/12.5/20 without rubbing on the inner fender well or anywhere else, or if 11.5 width is about the widest you think you can go with the current offset and conditions.
I would have to take a look at my wife’s stock limited and take some measurements. Overall you will gain 3/4”of height per side over stock 275/55/20 (I’m assuming thats what you had stock) and about .20” each side width wise. Then your adding the .5” for the difference in +44 and +30 to overall distance from hub for a total ofOK my turn.. What about 285/60/r20 on a on a rim with a +30 offset... Without any mods?
Sent from my LM-G710VM using Tapatalk
