22 Timberline headlights
Aj26
Concord
Is there any brightness/aim adjustment for 22 Timberline headlights , in normal conditions they seem to be a bit dull and when it rains i can barely see more 30 ft ahead of me.
AJ82
There is no brightness adjustment. For aim alignment check the "ADJUSTING THE HEADLAMPS" section of the manual. It should have been aligned correctly at the factory. Can't hurt to check they did it.
BrianA
Spring Grove, PA
They leave much to be desired my xlt lacks this as well. It makes you wonder if they took a step backward going to the reflector housing vs the projectors that were on the previous model.
2020FordRaptor
Nevada
Yes Brights. Just joking, but no, no adjustments.
bigwilly
I've read the same thing a couple of time in different threads and quite frankly, I'm a little concerned about my incoming 2023 Limited SPP. I really like the lighting on my 2017 F150 Plat. It would suck to go to something a lot worse on the Expy. I guess I'll find out
Rob6805
Yes, Ford did take a step back in going with reflector LED on the 22's as opposed to projector LED's which are on the 18-21. Cost cutting I imagine.
mdecillis
Iselin, NJ
I do not see any difference from my 2019 Limited with LED to my 2022 Limited. I did notice how the auto high-beams get progressively brighter as they turn on, almost like they are raising upwards.
rd618
new york
Lights on the 22 are more than fine. They work very well.
I have had several cars with varying LED/Zenon/Halogen setups, reflector and projector. These are very good throw, wide coverage, and bright. Not the best I’ve owned (BMW takes that), but definitely the best reflectors.
Also the dimming high beams are a nice touch. (These lights are fixed and have no moving parts).
