There is no brightness adjustment. For aim alignment check the "ADJUSTING THE HEADLAMPS" section of the manual. It should have been aligned correctly at the factory. Can't hurt to check they did it.Is there any brightness/aim adjustment for 22 Timberline headlights , in normal conditions they seem to be a bit dull and when it rains i can barely see more 30 ft ahead of me.
Yes Brights. Just joking, but no, no adjustments.Is there any brightness/aim adjustment for 22 Timberline headlights , in normal conditions they seem to be a bit dull and when it rains i can barely see more 30 ft ahead of me.
I've read the same thing a couple of time in different threads and quite frankly, I'm a little concerned about my incoming 2023 Limited SPP. I really like the lighting on my 2017 F150 Plat. It would suck to go to something a lot worse on the Expy. I guess I'll find outThey leave much to be desired my xlt lacks this as well. It makes you wonder if they took a step backward going to the reflector housing vs the projectors that were on the previous model.
Yes, Ford did take a step back in going with reflector LED on the 22's as opposed to projector LED's which are on the 18-21. Cost cutting I imagine.They leave much to be desired my xlt lacks this as well. It makes you wonder if they took a step backward going to the reflector housing vs the projectors that were on the previous model.
