4th Gen Apperance upgrades
BlancoDiablo
Just got a 2020 EXP limited, black on black. Need appearance upgrade ideas, post'em up.
I'm thinking Chrome Expedition lettering for the front hood, red tow hooks, maybe a raptor skidplate, possible switching the tail lamps out with a newer 2022/23., and a Raptor Engine Cover. On that note what is the difference in a limited vs Platinum engine, is it just a tune?!
Give me some photo ideas fellas.
2020FordRaptor
Nevada
It's just a tune. 380 HP vs 400 HP.
B
BlancoDiablo
Hey, 20hp, is 20hp lol. But I'm thinking more like maybe 100hp gain lol. Reading about some 5 star and Livernois, anyone running them?
Polo08816
MD
If it were so easy and there were no downsides, they would have done it from the factory.
B
BlancoDiablo
I've tuned every vehicle I've owned? Except for my last two trucks. They were extremely easy, and I had no issues, what downsides do you speak of?
ExpyNole
Sarasota, FL
They would.
If there were no accountants and the bottom line didn't matter.
But we live in the real world where the bottom line matters more. So what's your next argument against it, that holds water?
The rest of y'all, if you spend any time working where gloves are needed, happy holidays: https://slickdeals.net/f/16333648-m...y&prop=rcmid-b104eb0317ee602ae8e3e83652af97a1
MattG
Toronto
I understand the itch as I don't ever leave a vehicle stock.
To date on my '22 SPP that may give you some ideas:
Wheels (3 sets, ha.)
Front window tint
Black out chrome belt line
Raptor engine cover
Ford cargo liner
3 row all weather mats
ExpyNole
Sarasota, FL
Front window tint
Raptor engine cover
Ford cargo liner
the Ford cargo cover is a gamechanger. As cheap as it feels, lol.
SyndicateZ
Mass
They would.
Did you say you are purchasing these gloves for all the forum members for Christmas? Thank You!!!!!!
Polo08816
MD
I refrain from tuning while I'm under a factory warranty or extended factory warranty. I don't want to give any manufacturer an easy and immediately visible reason to deny a warranty claim for the powertrain (the most expensive component to repair/replace if there's a catastrophic failure). I've had a ZF 8HP eventually fail from "hard driving" (aka track use) that was covered under the extended warranty because the powertrain was stock. I'm sure if the flash counter for the ECU didn't match with what BMW was tracking for the car and my transmission failed, I would have been replacing it out of pocket.
They would.
Right - I'm sure the accountants assessed that the bottom line (increased costs) would be associated from warranty claims for repairs that are strongly correlated with loads and duty cycle. This is why light duty truck/SUV segments may see detuned powertrains. This is probably more apparent in GM's V8s between their performance cars versus light duty trucks/SUVs. It's even more apparent in the medium duty segment with 3/4 and 1 ton pickups vs chassis cab configurations. The more severe use that is expected, the more likelihood you'll see de-tuning to maintain the same warranty period.
ExpyNole
Sarasota, FL
Nobody is de-tuning anything. They're tuning for a 'competitive' power figure, and nothing more which they can also build in NVH standards and meet emissions and mpg requirements, and leaving available "steps" in power increases without having to generate a new product. Hence the 370hp being bumped to 380, or the 2020/21 platinums being rated at 400hp with the standard gen2 3.5eb, whereas the new stealth performance is 440hp, 510ft-lbs, so as to not 'step' on the raptor. At the end of the day it's all towards a bottom line.
Polo08816
MD
De-tuning is common when the exact (or nearly exact) engine is expected to be used in a more severe use scenario.
For example, the 7.3L V8 is rated around 430hp and 485 lb ft peak output for the F250/F350.
The same 7.3L V8 is actually detuned in the chassis cab configuration for the F600 down to 335hp and 468 lb ft because it is expected to have a more severe use case.
Also of note, the passenger car/light duty truck and HD pickup power output ratings are not measured the same way. Passenger car/light duty trucks are rated largely for transient (peak) power and not sustained power. A passenger car/light duty truck engine would likely experience more failures than a HD pickup engine if there is a peak power demand for any sustained period of time (> 30 mins of continuous peak rated power output).
I'd be wary of using an aftermarket tune for substantially more peak power if they are planning on doing a lot of towing with their light duty truck - particularly up long grades. If you're doing nothing more than 10 second pulls on a flat highway, perhaps you are not pushing the vehicle to the point where it would become an issue.
I see the appetite for tuning vary between the drag racing crowd and the HPDE/road course crowd. The former is far more likely to tune their vehicles for substantial power increases. I see far more stock or close to stock powertrains for the latter crowd. The use cases are different. The drag racing crowd is stressing out their powertrain for 15 seconds or less at a time. The HPDE/road racing crowd is demanding substantial power output over a far greater period of time (> 20 mins or more per session).
With that being said, I have a "tune" on my track car but it's to deal with the CEL from a catless downpipe. The map for the tune is completely stock. And that motor still sent a connecting rod through the oil pan which took out my steering rack in the the process after 150,000 miles with extensive track time.
B
BlancoDiablo
.... So, back to the original Question. Who's running 5 star or Livernois, My last tune I used a Sniper, it came with 5 modules me and some buddies split the cost so we each got a module. But I digress. MY Lst EB was a 16 Explorer Sport, Gen 1 EB. I didn't tune it because I read the PTO was the weak link and 400+ was asking for premature failure, clearly the EXP, doesn't have this fault.
B
BlancoDiablo
And side bar, has anyone tried to see if the Navigators HUD will work with a EXP? I like it better than 3rd party.
SyndicateZ
Mass
I still dont see the need to tune the expy that has the "Sport" mode from factory. Unless of course you plan on taking your EXPEDITION to the dragway and do real competition stuff...
B
BlancoDiablo
You do you boo. I hate to say, I've been a member of Mustang, F-150, and Explorer forums, y'all are about the most snobbish and least helpfull. If you don't want to do anything to your Expedition, then don't. But stop ******** and complaining to the folks that do. Contribute to the convo productively or go away.
GixxerJasen
DFW TX
Because I want max hp getting on the freeway but once I'm settled I want it to go into top gear to cruise till I'm ready to pass. Sport mode won't do that.
