2018 Hands Free Liftgate not working
719c6
Missouri
2018 Max Platinum with the hands-free option not working. All other methods work fine and the option is enabled on the dash options. Bought it used so no idea if it ever worked. Where and what do I need to check?
Bmanxx13
Arizona
Not missing much. It works about 40% of the time I try to use it. I have an '18 Max as well.
You can try disabling and enabling it in dash options. If that doesn't work, have you checked your battery? Random things stop working once your battery doesn't hold a high enough charge.
GixxerJasen
DFW TX
Take a look and see if the previous owner unplugged the sensor. Many of us have done this because it's more of a pain than it's worth, especially if you do things with the hitch like bicycle carriers. I have a nice dent in my hatch thanks to something that fell and rolled under the truck while I had stuff on the hitch.
GixxerJasen
DFW TX
Do you know where I can find a diagram/location for the sensor?
This forum. Post number 22 has pictures.
719c6
Missouri
Thanks. Got under and everything is plugged in. Is there a way to test or determine why it is not working? Guess I'm gonna look in Forscan and see if there is an option to delete/undelete this option.
Rob6805
How do you know it isn't working? Are you kicking under the bumper correctly? It's a crappy system. I probably look like an idiot trying to get it to open. Probably less than 50% rate as to whether it works or not.
GixxerJasen
DFW TX
This, it's easier to activate it accidentally when you don't want to than when your arms are full of stuff and you need it to work. Make sure you are kicking in the right place.
719c6
Missouri
Tried from about all angles and methods. Verified everything plugged in and activated in Forscan. I'm out of ideas... anyone?
LG_123
Toronto
Mine works almost exclusively when i don’t want it to like when hitching up a trailer. I was excited about that feature too but I’m afraid you’re not missing much.
719c6
Missouri
Anyone have access to the service manual steps in diagnosing the components?
jwas1
Newport News
I have '18 XLT. Worked for a few months. Then lift gate started opening by itself. Caught me on the forehead. Dealer tried everything without success. Disabled kick to lift.
Tuebor
Detroit
I have the same luck as the other posters: won't open when I want it to. Closes on my head when I don't want it to.
GixxerJasen
DFW TX
mpc11
MI
I had an '18 and now a '21. Accidental activations aside, I could barely get the '18 to work when I wanted it to. I feel like I had to start more towards the driver side than center and kick at some weird angle for the times I did get it to work. The '21 works pretty flawlessly with a simple short kick starting at the center.
Also, if memory serves, there was some kind of TSB for the hands-free liftgate on the '18. It helped some w/ the accidental activations, but still wasn't great.
Johnb21
boston, ma
I know this may sound silly, but do you have your key fob in your pocket when you try to kick under the tailgate on the driver's side 2x?
I chased the tailgate not working when activated with my foot for many, many months. Dealer chased it too, but it worked for them....until they asked the question about the key fob. I have never had an issue since. Also, one other poster did mention battery voltage. I am currently having issues with door sensors and start-stop due to my battery not charging to the ideal voltage.
wakeboarder
Fort Lauderdale, FL
There was a video somebody posted on how to get it to work 90%+ of the time. I think it was from a dealership in Salina Kansas. Basically start one to two steps back. Walk forward, kick under the bumper then back up those two steps.
Book2
Torrance, CA
Hi I have '18 Limited since new and enjoying the car very much! It took me about 1 year to master the correct way to do it, thanks to one comment I received from someone at YouTube - I commented about the difficulty of foot operation and he gave me an advice - it really works! Now I think I can make the rear gate open by my foot at more than 95% success rate. Here is how - about half way between left side and license plate, kick in and out quickly - literally I am gently kicking the spare tire like a soccer ball, and my toe hits the tire. Sometimes it takes me 2 or 3 kicks but usually I can open / close the gate by one kick. When it works good, it's kinda fun, and I am using the hands-free operation very often. I hope you can make it work, too!
719c6
Missouri
Went thru the service manual and followed steps. Found out the rear antenna was not working... helps if it's plugged in. doh. All works great now.
