Transmission slow to up-shift when engine cold?
Deadman
my 18 Expedition trans has ALWAYS shifted flawlessly in my opinion. It has 40K on it now, and its starting to act funny. When the engine is cold started (60F) and the first 5 minutes you drive it easy,..... When it goes to upshift, there is a much more noticeable delay in the shift and it stops accelerating for a full second and then upshifts and then accelerates as it should. It does this on all the first 4-5 shifts getting up to speed. Once it warms up (5 minutes maybe), this BS all stops and it shifts normal again.
Is this some stupid Software Update that ford recently did, or have any of you experienced this? I hate to even waste my time at the dealer now, because that means taking it the day before and letting it and then the tech will just say its normal, so screw them at this point. Anyone else have this issue and get it resolved? I have 125K warranty if needed, so I'm not worried. :)
lv2drive
PA, USA
my ‘19 does this EVERY time i start it up & drive gently when it’s cold / but only seems to be between 3-5 like it’s trying to figure out whether to choose 4th or 5th.
has done this since i got it at 35k 2yrs ago - no software updates - not sure if same but sure feels like it gets stuck between the gears. 5 minutes later drives fine / only the top of the morning first shifts. if i warm it up , doesn’t do it. 2wd / 4wd acts the same
D
Deadman
Pretty similar to mine. It just started doing this, so I haven't paid real close attention, but its getting annoying now that it does it daily. By the time I realize/remember that its doing it, its already changed gears, so I can't look at the gear indicator to see what gears its changed. I'll TRY to look closer. Its a real hassle, because if I pull out into some traffic , I try to accelerate enough to not annoy the other cars, but it hesitates SOOOO munch in between gears now that it feels like you aren't getting up to speed in time. (obviously the engines cold, so I'm not hammering it hard)
My wifes 18 Navigator did this exact same thing, but hers was sooo much worse. Like hers literally took 3X as long in between shifts and absolutely stopped accelerating completely and they when it upshifted, it threw you back in the seat because you continued to add throttle input to get moving. It was nearly violent. I sold that POS thinking all those things were behind me.......
HansS
WI
@Deadman my 2019 is doing exactly what you are describing. Just curious if you ever got it resolved and what the fix was? Thanks!
jwatso4
Wheaton IL
I just dropped my 18 Max Plat off at the dealership for this exact reason. For me I would back out of my driveway like normal but when I shift to Drive, it felt like limp mode. No power, RPMs drop to idle no matter how much gas I was giving it. Other times the RPMs would increase with throttle response but felt like the torque converter was slipping and no power was getting to the wheels. This also only happens in the first 30 sec. Once I am up and moving it never happens again. We will see what the find.
byathread
Pennsylvania
Some here, 2019... It is the shift from 4-5 for me and started around 40K miles. No software update, but, trans did get reset and re-learning did its thing prior to this... I no longer use eco mode, not sure if they had/has any bearing on it...
HansS
WI
Interesting you mentioned that this didn't start until the trans got reset and re-learning did its thing". Now that you mention that I believe the dealer did that same thing for mine when the cam phasers were replaced. Don't recall it happening until after that. Last week I used the forscan tool to reset the adaptive learning so I guess I will see how things go as it "re-learns". Not sure how long that is supposed to take. This does seem like a computer problem versus mechanical.
TheDoug
Mansfield, TX
I also have this exact same issue... I never took it in because once it was warm it shifts great. (And I hate going to dealership)
Please post back if there is a solution to this.
HansS
WI
From what I have observed it seems that the reason this weird shifting behavior is seen when the engine is cold is because of the slightly higher RPMs and seemingly the computer gets "confused" on which gear to shift the transmission into. As soon as the RPMs come down to normal the weird shifting pattern goes away.
Just curious if others see a similar pattern?
As @TheDoug mentioned, please post a solution if you have come across one.
jwatso4
Wheaton IL
I ended up getting the cam phasers replaced, which I needed, but they assumed that was going to fix the shifting problem and didn't do any additional investigation. I can say the slow shift when cold is still there. I am in chicago and park outside. Today I let the car fully warm up in the driveway while I cleared off all the snow and the RPMs were back down to low idle before I backed out. I can say high RPMs is not my root cause. I still lean more toward cold trans fluid causing slow shifts.
HansS
WI
Interesting. Thanks for sharing. I was going to have the shop check the transmission fluid level to rule that out but it seems that may be a waste of money. Has anyone ruled that in or out?
HansS
WI
HansS
WI
This TSB seems to relate to what we are all describing -
I spoke to a local Ford service advisor a few days ago regarding this TSB and he seemed to be familiar with it. He said that the step -
"2. Reprogram the transmission strategy download into the PCM/TCM strategy download into the PCM/TCM."
can actually introduce other odd behavior. He suggested that I first disconnect the battery overnight (this may be overkill but whatever). From what I understand this will reset the KAM where the transmission adaptive tables are stored. I went ahead and did this and it seems to have helped so far - two days in. I still see a slight delay when cold but it is definitely better. This may just be normal behavior at this point.
In regards to the second part of step #2 -
"Perform the adaptive learning drive cycle. Refer to Workshop Manual (WSM), Section 307-01"
He didn't mention that this was necessary. In any case it seems to make more sense for the adaptive learning to learn when the temps are cold where the odd shifting seems to happen.
I did ask him about checking the transmission fluid level and he indicated that if the level was truly low that I would be seeing a service engine light.
Anyway, thought I would pass that along.
mwar99
NJ
Isn't any transmission going to be slightly delayed when it's cold out? Or are we talking about a transmission in warm weather but not warmed up from operating yet?
HansS
WI
Thought things had improved or were improving...today truck threw a P0734 which is a code referenced in the TSB I referenced above. Truck goes into the shop on Monday.
Stay tuned....
HansS
WI
Bad news for everyone who is experiencing this problem. I am at the Ford dealership. I have found out that this is an indication that the clutch packs in the transmission are worn\wearing out. The reason this problem clears up when the transmission warms up is because of part expansion. I was also told that folks are getting between 70,000 and 90,000 out of these 10 speed transmissions. I have 90,000 miles on mine. I guess I will be calling Ford today to see if they would be willing to help pay for a new transmission. Apparently they are putting better parts in the newer ones. 4-6 weeks to get a new one with a bill around $5,000. I am not happy and this is what I get for taking the risk of buying a Ford.
apex96
Bad news for everyone who is experiencing this problem. I am at the Ford dealership. I have found out that this is an indication that the clutch packs in the transmission are worn\wearing out. The reason this problem clears up when the transmission warms up is because of part expansion. I was also told that folks are getting between 70,000 and 90,000 out of these POS 10 speed transmissions. I have 90,000 miles on mine. I guess I will be calling Ford today to see if they would be willing to help pay for a new transmission. Apparently they are putting better parts in the newer ones. 4-6 weeks to get a new one with a bill around $5,000. I am not happy and this is what I get for taking the risk of buying a Ford.
Common issue with the 10R80 trans unfortunately. I dealt with the same issues. Remedy was a new trans from Ford. My issues and remedy are documented in the link below.
Dice Roll
Craps Table
Mine started doing this the next winter after we bought it. It arrived at the end of the winter and was fine until cold weather came back. I think it had like 5k miles when it started hammering from 3 to 4 and again going into 6th.
I posted in here and nobody seemed to have anything like that happening back then, about two years ago. I called the dealer and they said it’d be hard for them to speculate and there were no software updates that applied.
id read on here about the can of worms that is a tear down. I decided to just let sleeping dogs lie for now and bank in the extended ford warranty covering it if necessary at some point. I’m up to right at 20k miles now. Still does it, only first time through gears. I’ve only towed 2-3 times and the first time was well past the 1k break in period.
