The vacuum line is not connected to anything
wpatters1229
Pleasant Hill CA
2003 with 5.4 engine. There is a small vacuum line that is in the rear of the left side of the engine bay. It comes off a connector with two other larger vacuum lines. It is a hard plastic line and the end is cut at a diagonal. Can't find what this is all about. It has a vacuum on it at idle but when plugged does not make a difference in how the engine runs. Is this a vent or what? It is about 6" long. Here is a picture I found on the internet b452f66dab7f91bb481d64e177139874.jpg
whtbronco
Winchester, VA
I suggest it's one of the vacuum lines for the front 4wd vacuum hubs. If I'm correct the solenoid for the vacuum lines is on the left side of the picture you attached mounted on the firewall. Mine broke years ago as well and I just re-connected it with a 2" piece of vacuum hose.
BlackCoffee
SOMD
I don't think this is the vent for the 4x4 hubs. That is usually down by the shock column, hard to see, and is turned down to prevent water from entering (like on a ship). The line you are looking at should have a T on top. On one side is goes behind the battery to the air box. The other side snakes across to the valve on the right side of the throttle body.
W
wpatters1229
Pleasant Hill CA
No the line I am looking for to find out where it goes is the one that has a diagonal cut on the end and the end is sitting on top of the battery post. It is a thin plastic line but does have some vacuum. So far I have plugged it up but it must either connect to something or is some kind of vent but then why would it have a vacuum? It is connected to a fitting that has two other large rubber lines connecting to a check valve. plugging it or not does not seem to make the engine miss.
Hamfisted
Ft Lauderdale
I'm gonna go with dash vent solenoid supply line for a hundred Alex . If it has a vacuum on it with the engine running it's a supply line to something. The only hard plastic line in that area is the dash vent control supply line. Hopefully you find the other end of it poking out of the pass-thru grommet there just below it on the firewall. You can splice them back together with a short piece of rubber vacuum tubing. Can you post a picture of your actual broken line ? In the internet pic you posted you can see the broken supply line sticking out of the pass-thru grommet in the background.
whtbronco
Winchester, VA
Oh my goodness that was hilarious. Thanks for laugh.
That HVAC related line seems to break fairly commonly.
W
wpatters1229
Pleasant Hill CA
I know what you are talking about. I bought my 2000 expedition from my neighbor who said the vents in the dash only blow out the defroster vents. I fixed the broken hose you speak of with a hose connecting the two pieces and everything now works fine on the dash. He was told by the Ford dealership they would have to pull the dash apart to find what was wrong. This hose I am looking at is on a 2003 and it looks different than my engine bay. But I will look more carefully since I may have missed it since the hose is not cracked like mine was and has a distinct diagonal cut on the end. I also do not believe my brother-in-law said anything about the dash vents not working right.
ExpoLady
After changing out all the other hoses, I have came across several broken vacuum lines in that area. Can anyone tell or show me which ones go to which? 1st pic: yellow 1 - electrical hookup to solenoid.Green 2- 1st vacuum lines. That has a T drop to the Blue 3- hard vacuum line that goes behind battery. Purple 4- water tubing to windshield visors. White 5 solenoid on wall has the shape of an "E".
ExpoLady
More pics
ExpoLady
Pics of broke vacuum lines . I thought one line came behind battery and around to solenoid on wiper fluid canister
Hamfisted
Ft Lauderdale
Somebody cut your hot water supply lines and made hamburger of everything. I can't tell if you have a vacuum supply line going into the firewall grommet or what. I assume you're not the original owner?
ExpoLady
Hamfisted
Ft Lauderdale
That's your front windshield washer line, and it should be plugged into the washer pump. One line goes to the rear washer, one line goes to the front.
ExpoLady
No. I'm not the original owner. I have 4 lines that I don't know where they go. The vacuum line in first pic The supply line from that grommet that has this 3 prong check valve attached. The hard plastic broken line that comes from back of battery wall and a skinny black rubber line that comes from the bottom across the wheel well. They all 3 meet at the corners of battery and PCM. So I assume these are connected by this 3 prong check valve? < (Not including vacuum).Green in this first pic is the vacuum coming from grommet. Red is the 3 prong check valve. In 2nd pic I am holding the hard plastic broke line comes from behind battery and the skinny rubber one that comes from the wheel well. 3rd pic shows skinny rubber one and another that comes from across wheel well .
Hamfisted
Ft Lauderdale
In the first pic, that line that you have green writing pointing to is your hot water valve vacuum line. Attach it to the hot water valve nipple.
ExpoLady
Ok. If that goes there, then where is the last vacuum connection on vacuum coming from other side? Speaking of the heater Core vacuum valve. As long as flow arrows are going the right way, does it matter what side vacuum is on? The new one came from manufacturer twice, opposite from old one. Is this Fords way of getting vacuum out of outlet lines way for better access?
ExpoLady
@Hamfisted would you kindly take pics of your engine bay, so that I can compare my throttle body lines with yours? Where does the line that comes off of the nipple at the very back left side of engine(on the under manifold line) connect too? I'm not sure I have mine placed correctly. Trying to double check I have everything placed right.
wesley
Harlan ky
These hoses go to the pcv valve to intake crankcase their is one big hose then that branches off in a t one hose runs behind battery box and one through firewall
ExpoLady
Ok ty. I'll go back n check it out. I took that check valve out ran all new vacuum hoses. She's running great! But brake booster doesn't catch/ not as tight when it kicks in on braking. It has to be something with the vacuum is not quite right. That's the only change that has been done, dealing with brake booster.
