Jackie6422
I just put in a new evap canister, but my ford 2017 expedition is still not taking gas. I can pump about .5 gal and the pump shut off. Anyone know what I should check for next?
Is the canister vent solenoid / line working correctly? When air is displaced from the tank it flows through the Evap canister to collect the gas vapor and then the cleaned air flows out the canister vent solenoid. If that is not happening it will back up and kick off the nozzle.I just put in a new evap canister, but my ford 2017 expedition is still not taking gas. I can pump about .5 gal and the pump shut off. Anyone know what I should check for next?
When I replaced the Evap Cannister I was complete with a new vent solenoid. So the Solenoid itself isn't the problem, could it be the line?Is the canister vent solenoid / line working correctly? When air is displaced from the tank it flows through the Evap canister to collect the gas vapor and then the cleaned air flows out the canister vent solenoid. If that is not happening it will back up and kick off the nozzle.
Do you know if the solenoid is opening / closing? If not that could be cause. Could be the vent line or as suggested above, some sort of blockage in the filler neck. Do you have or can you borrow a borescope? If so, you can put the plastic emergency fuel filler funnel (see pic below) into the filler neck to keep the filler flap open (it is in the jack compartment under the cargo area hatch) and feed the borescope down the filler neck to make sure it is clear.When I replaced the Evap Cannister I was complete with a new vent solenoid. So the Solenoid itself isn't the problem, could it be the line?
I don't have a borescope, how do I check to see if the solenoid is opening/closing?Do you know if the solenoid is opening / closing? If not that could be cause. Could be the vent line or as suggested above, some sort of blockage in the filler neck. Do you have or can you borrow a borescope? If so, you can put the plastic emergency fuel filler funnel (see pic below) into the filler neck to keep the filler flap open (it is in the jack compartment under the cargo area hatch) and feed the borescope down the filler neck to make sure it is clear.
Since my 2017 Expy is 1250 miles away from me right now I can't look at it for you and I don't want to assume the 2011 do I have with me is the same, so I'm posting a Ford diagram, which, in theory, is correct for the 2017. It shows the purge canister with the vent valve (7) and vent valve solenoid (8) to the right and below the canister.Correct me if I'm wrong, is the vent hose the hose connected to the solenoid? and also thanks for the info about the borescope!
The funnel is already in your truck. From Above (it is in the jack compartment under the cargo area hatch)Ok thank you so much for your help I"ll let you know how far I get next week, should have the borescope and funnel tomorrow.
As I said in an earlier post, this is my 11 Expedition, which even though it has HD Tow, was not available with an OEM Trailer Brake Controller. The pigtail in the bag is the TBC adapter that came with all HD tow vehicles. Since I didn't tow with this truck, I never needed the adapter. During the early years that I owned the 11, I also had a diesel Excursion that handled all our HD towing needs.I noticed on your picture a clear plastic bag with items in it. Is this also something that comes with the vehicle and if so what is it?
