'23 towing with HD tow - what are ppl using for keeping level?
Kreutz73
Canada
Just traded in our 16 limited for a 23 platinum. I've towed a race car trailer since we had our 2007 expy. The air level in the '07 was fool proof. The auto level dampeners they went to on the '16 worked well but you always left after initial hookup with a little sag, it took a few miles to level itself out.
now it looks like the expy's have nothing, the 23 just has ccd shocks which I don't believe do anything to help with level. anyone doing aftermarket airbags or anything like that? what are folks doing to keep good level and decent handling?
nationalgallery
Would a sway bar/weight distribution hitch work? Haven't trailered with the Platinum yet, but had one for all my Navigators before this.
Jon2099
Indiana
If you are towing within the weight limits of the 23 Platinum then a properly configured weight distribution hitch will work to keep everything level. I use an Equalizer hitch and it works well for towing our ~75000 lb loaded trailer. It, and many other weight distributing hitches also help control sway.
JasonH
Houston, TX
Check the towing guide. You need a weight distribution hitch over a certain tongue weight.
BIGRED03
Fla
That is a lot of weight!
LG_123
Toronto
If anyone has put air suspension in their Expy for towing reasons, I’d also be interested to hear about your experience.
chuck s
Airbags are only designed to level the vehicle with an internal load -- cargo and passengers -- not to level the truck with a load on the trailer hitch -- a cosmetic level. Any trailer over 6,000 pounds requires a WDH which distributes -- the D in WDH -- the tongue weight some to the front axle and some back to the trailer axle. Safe towing of conventional trailers requires a minimum of 10% of the trailer weight on the ball or in this case 750 pounds which may exceed the cargo capacity of the SUV is there's a bunch of stuff inside.
Without a WDH there's much less weight on the front (steering) axle which makes handling squirrely and unsafe. WDH puts much of it back.
Equalizer(tm) 1,000/10,000 pound WDH works for me and has for 20 years. Same trailer, same WDH, 3 different SUVs.
-- Chuck
RSNovi
MI
I used to regularly tow a 34' travel trailer (total length including the front hitch area) about 8500 pounds with about 850 on the hitch using a 2020 Expedition Limited standard length. I used a weight distribution hitch like the Equalizer. Mine was the Husky brand.
The Expedition was always level with this hitch. We pulled the trailer from Michigan to Myrtle Beach last year. It actually towed reasonably well and I don't think the weight was really an issue. It was the length of the trailer and wind. When it was windy it would get a bit stressful. Today I use a GMC 2500 HD to pull, but I we still have the Expedition and wouldn't hesitate to pull with it if needed.
Speedboosted
PNW
WDH will be your answer, and most of them offer some sort of sway control which will also improve the towing experience. I use a Fastway E2 on my 2017 and it's great with a ~6k lb trailer hooked up.
VBreithaupt
I had two GM SUV's with air bag leveling. Loved them. I tow a 32 ft toy hauler and have the same ride level from a WDH. The WDH that have the sway control build in them are the best. Then you don't have to install a sway bar as well, but you can get the WDH at Harbor Freight and it will do the job you need.
BigRedTruck
I presume you have a sway bar. If not, it's easily added.
We tow a ~7000 lb (29') travel trailer with a 2021 Expedition (has HD tow package). When we upgraded to the larger trailer, we switched to a sway CONTROL hitch (from Blue Ox). It actively pushes the trailer back into position behind the truck. It makes the the truck a bit twitchy in a crosswind, as the force to push the trailer back into position gets transferred to the truck. But once I got used to that, we have never had a problem with sway.
To anyone following this thread: I can't stress enough... be sure your weight distributing hitch (WDH) is adjusted correctly. Measure the height of your fenders on level ground without the trailer, then repeat after hitching the (loaded) trailer. If the front fenders are higher, you are likely UNLOADING the front axle, and that can be really bad.
Once you are satisfied with the height of the fenders, take your loaded truck and trailer to a scale and weigh all the axles (front, rear, trailer). Create an account at weighmytruck.com and you should find a public scale near you. Just drive on, open the app and click, and it will send you the results. Next, repeat without the trailer, and compare the results. Also, confirm that the axle weights are within the limits in the manual.
ColoradoJon
I use an E2 Fastway as well, non-max and it works well for our 27 ft ~7500 lbs trailer. WDH is mandatory after 6k like was mentioned. There are quite a few threads on this topic in the forum. Good luck with the tow, I notice not a lot of car haulers have WDH setups, I am sure they are above 6k loaded. 2x what BigRedTruck says, do the work to make it safe and heed the limits.
duneslider
Utah
My trailer is only 5k and I feel even that is way better with a WDH. I once had a trailer that was only 2100lbs that had trailer breaks and I was sold on trailer brakes after that. It technically didn't need the brakes but was so much better to pull with them. The WDH is the same way, just so much nicer to pull with one.
LazSlate
Arizona
The consensus by far is a weight distribution hitch. I agree 100%. Those do wonders. If your back end is sagging low its a sign something is not right. Too much Toung weight or uneven distribution. Worst thing you can do is try to upgrade the suspension to fix the issue as its working how its supposed to and telling you that you need to adjust the trailer with a WDH, etc. (granted the trailer is in spec with the suv)
Deep8174
Canada
I am an Andersen WDH convert and love it. No more squeaks and rear axle hopping over bumps. Much more lighter and easier to set up (reduced payload #s). Got it dialed in correctly and it tows great.
CCDC
Clearwater, Fl
I tow a 28' travel trailer with a 10,000lb equalizer wdh and added the sumo helper spring. Helper springs seems to help a little, but no airbags for our expys are available. Shocks are inside the springs so no room for airbags to go which I had on my previous escalade setup. We're right at max tongue weight (I bought a scale) and it sags a little more than I'd like. The hitch has as much tension on the bars as I feel comfortable using; could probably use the 12,000 hitch. I think its a byproduct of the IRS vs solid axle setup for towing.
chuck s
Your tongue weight is 920 pounds? How heavy is the whole trailer?
12,000 pound WDH won't change the maximum towing capacity which remains 9200 pounds and maximum tongue weight stays at 920 pounds. The way I understand this is the WDH weight bars need to have a bit of spring in them to absorb shocks but I don't know the structural ramifications of bars that are too rigid.
-- Chuck
JVinOlathe
Olathe, Kansas
-- Chuck
This is an excellent reply with correct information. Many are under the impression that the max. allowable is what they can tow safely, or in some case, just a suggestion. In reality, the max. allowable requires other factors to be met and the actual max "allowable" is much lower. This is a very good video that outlines the factors involved in towing.
People need to realize that if they are towing outside the actual limits and there is an accident, the insurance company will most likely refuse to cover.
