Cigarette lighter in 2003
smo0othride
San Diego, CA
I have a 2003 XLT and I can't get the cigarette lighter to work. I thought it was as simple as pushing it down, and it will pop out when it's ready... but it never pops out, and if I pull it out manually, there's no sign of any heat. I tried looking it up in the manual but couldn't find anything on it. Is mine defective or am I not doing something right?
Fred69
Unless you have the smokers pkg. This is merely a 12v outlet, and will not support a lighter properly.
S
smo0othride
San Diego, CA
7 years later and this still doesn't work!!!! I'm thinking about trying this universal replacement: http://www.car-stuff.com/2003fordexpeditioncigarettelighter.htm
ELVATO
Orlando, FL
Does it receive power? If you plug something in there, does it work? If so, then it's the lighter part itself. Granted, it seems if you just get the part you linked, you'll get the part for decently cheap since the seems to be at least that price on ebay for used parts. None of them are for our gen Expedition, though.
S
smo0othride
San Diego, CA
It doesn't receive any power, I wasn't sure if it was supposed to because it has never worked. If I had known I could use it as a second 12v I would have fixed it sooner.
S
smo0othride
San Diego, CA
I think it's more of an issue whether there is the bench seat or center console, if there was a "smokers package" it would have been listed on the window sticker.
S
smo0othride
San Diego, CA
After 7 years of not working I finally have the new part sitting on my desk, now I wonder how many years it will be until I decide to install it..I'm hoping by the end of the summer to get everything 100% functional on my expedition... probably going to spend about $6,000 in repairs, the car's only worth $7,000 but so far there are no new expeditions that impress me so I just have to stick with what I have.
LameSuburbanDad
rockwood, MI
that's right, there are a very small number of things that can make it not work,
1 its not a lighter, it's a power outlet
2 the fuse is bad
3 one of the two wires that plug into the back of the "lighter" are not plugged in somewhere in the line. I would start at the back of the lighter and make sure both wires are secured not only to the lighter, but also crimped securely and not arcing.
if everything seems to check out then visit your local auto parts store, they can furnish you with a replacment hotstick.
