2004 EB 5.4 Stalling when cold P0320 & P0351-P0358 Can't find the short
tswinehart
tswinehart
Milton, GA
Yeah, I'm using an OBDLink EX and FORScan. I haven't been checking fuel trim lately, I've had all the misfire pids and some rpm and cam sensors. Will throw fuel trims back in. One thing I can't figure out with FORScan (I'm new to it), is how to change the oscilloscope to look at different PIDs when I'm loading and examining an existing log file?
  • after cleaning intake and replacing pcv.zip
Hamfisted
Ft Lauderdale
Ok, and how's the wiring harness look running from the crank position sensor there at the front of the motor just aft of the crank pulley ? That P0320 code could be the base of all your misfires really. If the harness is damaged, or the crank sensor is failing. Is it gummed up with schmeg like the PCV was ? Take it out and clean it or replace it and clear the codes. Then see which ones come back or how the motor runs.
Crankshaft Position Sensor at Rock Auto
tswinehart
tswinehart
Milton, GA
Looks like it's blocked by the a/c compressor, so that'll be a littler harder to check. Probably need to get it back on jack stands to get a good look.
Hamfisted
Ft Lauderdale
I can't tell what we're looking at there. Take a look at the crank position sensor signal, and the ignition coil signals for all cylinders. See if a blip on the crank position sensor signal corresponds to a blip in the ignition coil signal or a misfire.
tswinehart
tswinehart
Milton, GA
Can't find any PIDs that are called crank or ignition or coil. I think there is not a PID for them, or it's just apart of some other related PID maybe?Screenshot 2023-08-24 190639.pngScreenshot 2023-08-24 190536.png
Hamfisted
Ft Lauderdale
My bad. It just shows up under the RPM PID graph. I'm not sure that'll be much help, 'cause of course the RPM is gonna blip during a misfire.
I see a mix of coil colors there on the motor. Who did all that ? Do you know how old the sparkplugs are ?
tswinehart
tswinehart
Milton, GA
Man, I was really hoping that was gonna fix it. What a pita to get to lol. No dice though, symptoms are exactly the same. Old sensor was pretty grungy though.PXL_20230825_143424514.jpg
tswinehart
tswinehart
Milton, GA
We're pretty sure the plugs and coils have all been changed by my uncle or grandmother at one point or another. Doesn't seem like they were done at the same time though, and obviously not with all the same parts.
jmdunham2
