GlennSullivan
I found this thread from someone on here who did the same project on the same 2014 year Expedition. I read through it and it is a fairly complicated process that involves adding wires to the main wiring harness (which runs the length of the vehicle) along with pins to the connectors and the necessary relays (relays the easy part). You would of course also need to obtain the switch assembly that fits into the passenger side rear trim panel. The person that successfully performed this surgery, used a main harness from a doner vehicle, placing it side by side to his to see what was missing and then moved those wires and connectors over to his harness.
***EDIT*** He ended up having issues with the ECU resetting and not recognizing the 3rd row. Rather than continue with the dealer and Ford, he installed a key switch adjacent to the 3rd row seat switches that would control power to the seat switches.
Before I read this, I was thinking that it might have been as simple as plugging in a portion of the harness that was not installed in vehicles with manual or no third row seat. Based on information in the linked thread, that is not possible. Vehicles with electric 3rd row seats have a different main wiring harness.
If you have the skills and time to do the project, the process is outlined in the linked thread, if not, then in my mind, the best route would be to find a set of manual 3rd row seats, possibly from the parts yard search site I linked earlier.
Another alternative is to use the factory switches and install your own wiring, relays and lockout device.
2014 Ford Expedition XL Adding Third Row
I have not seen this conversion, but I have seen interest in it, so I thought I'd go ahead and post it online. I purchased an ELECTRIC third row, wiring harness, belts, buttons, and interior moldings for my 2014 Expedition that doesn't have a third row. You can read about the purchase here...
www.expeditionforum.com
