I’ve been putting off attempting the external relay modification for years. I’ve been using a jumper to power the fuel pump for years. My Expedition has been sitting unused for just over 2 years. I’m returning to the office and need to get Bonnie road worthy once again. There are several things I’ll be changing, upgrading, adding, etc.
This is the first one I’m doing and then swapping out all her fluids. I plan on documenting everything in a post.
For this project, I’ve decided on a relay with a built-in fuse. And that fuse will be replaced with a mini circuit breaker. I’m also going to replace the color coded pigtails with silicone shielded wire for the flexibility.
@whtbronco I’m also wondering. Those of you that used an external relay, how did you anchor it to take the strain off the soldered ends?
