Low oil pressure
Harry
Dallas tx
Hello. This is for 4.6 2003 Eddie Bauer
After driving for a good 30 minutes I had a ring and it said LOW OIL PRESSURE the oil Guage would drop down then go back up. Can it be a sensor? Or the oil pump? Since I had this expy ( 6 years) when I had the key in ON position it would give that same warning. But nothing never happened till now. Please help and thank you
It sounds as though the oil pressure sensor is defective (common).
If the engine oil pressure was too low - you’d hear clattering from the engine.
It is also possible you have the incorrect engine oil filter and/or it is clogged (or your engine oil level is very low).
warbler
GA
I'm having the exact same issue. I just got the oil pressure sensor replaced today and it's still doing it. Oil level is good, oil is clean, no sounds, no smells, everything is running fine. I have a feeling it's a wire that connects to the sensor, but I really have no idea. Just praying it's not the oil pump.
H
Harry
Dallas tx
Yes that's what happened the day before it was clattering. But add oil. And it went away. But after driving a good 30 min. I received that message. I'll go get a oil change soon
H
Harry
Dallas tx
Did you do an oil change and filter? I'm going to do that sometime this week
engineer1
Alabama
If you continue to have a problem you may want to consider installing an economical mechanical pressure gauge to monitor it. This will tell you If really have low pressure, for any reason, or whether you have an electrical problem. When I rebuilt my EB at 187K I screwed my pressure tester into the fitting where the sensor goes and cranked it to be sure all was good prior to installation.
mhg1
EMT/First Responder
sav, ga.
You need to install a manual gauge and check the oil pressure. The light or gauge on the dash does NOT give you the pressure reading.
It only tells you the pressure is above 7 PSI. It's a fancy idiot light. If you are hearing clattering on start up, then there is a pressure problem.
Fix it quickly before you have a catastrophic failure.
