Need help wiring backup camera
07ExpyEL
Hey guys, need some advice before tackling this project. I bought a backup camera from Costco that will be hard wired into the truck. As far as powering the camera I had planned to tap into the backup lights in the rear. However, I am not sure where to get power in the front for the monitor. Are there empty spots in the fuse box? If so, how would I wire into that? Should I try tapping into the overhead lights? Truck is a 2007 EB EL. Thanks for any ideas.
Rob
dtd07
Oregon
not sure on 07, but on 06 if your vehicle is equip with a auto dimming rear mirror look for a 6 pin clip from behind, find a wire color black w/pink stripe. this is the reverse power tirgger (+). Not sure what its use for behind the rear mirror. if you have a volt meter test it first..
The same wire is also located on the 24 pin harness that runs from your navigation DVD-ROM to the head unit.
If you don't have this wire you can run the backup wire towards the front or I can search for a wire diagram. again I can only search for 06 years. It might be close.
98EXPY 5-0
Don't just power it from the reverse lights, use a relay.
98EXPY 5-0
whats wrong with using the reverse lights? someone advise me to do just that...
Because you are asking that circuit to pull more currrent than it was intended to do. I don't know what the current draw of your camera is, and perhaps in this situation with limited usage it might not be a big deal.
The more accepted way of adding anything to your wiring is to run a power wire from the battery to a relay, and to trigger the relay with the existing circuit (in this case, reverse lights).
Just my .02
Newport News, VA
Just my .02
so thats a no-no...
98EXPY 5-0
If its working, I guess its fine. It's not the "Wrong way", but it's not the "Right Way" either. It really depends on the Fuse rating and what the combined current draw is.
Newport News, VA
so what will be ideal? i have one that i'm waiting to hook up cuz itz still too cold outside to hook up...
dtd07
Oregon
a rely is only used when a "unit" is a high drain/amprage, such as a high power amp, off road lights or such. For a low drain unit like interior light, radio it doesn't need a relay. a fuse is a good idea from the power source to your "unit". A backup camera and a small monitor wouldn't need a relay. It wouldn't draw that much amps...from the looks of what you have in your Expy...you have a clear idea of what you are doing. Your back up system wouldn't be on for no more than a few minutes at a time if at all 60 seconds, your radio is on most of your driving time and it doesn't need a relay to keep it going.
Just my take.
Newport News, VA
Just my take.
take noted...
98EXPY 5-0
Just my take.
Thats why I said I don't know what amperage your camera will draw and about limited usage. It may not be an issue at all. I am thinking of adding a back up camera to my Expedition as well because my rear view mirror is useless with my cage. I am also going to be adding reverse facing flood lights and so I will already have a 12v source from the battery to the rear of my vehicle. So adding a relay will be easy for my application.
I only brought it up at all because I have seen guys hook a wire from their headlights to their driving lights and powered both from the same circuit. That is bad.
07ExpyEL
Thanks for the replies guys. The weather looks ok for tomorrow so I think I will try and get it done.
dtd07
Oregon
If you have a 7 pin towing hookup you can add your back up flood light to that..it is already setup with a relay. just a though
07ExpyEL
unfortunately I don't have the 7 pin hookup. That is my next project, I already bought the plug and will be using the instructions from another thread on this site.
