2015 Limited Backup Camera Replacement
Glock_19_9mm
Florida
Hello all.
First post but I have been bailed out many a times by forums so I am paying it back a bit...
Our backup camera started to have an intermittent black screen with a nice little pop up message to visit the dealer.. BAH...
Picked up an OE replacement online and did some searching on how to replace. Found a couple YouTube that came pretty close but missed some nuances..
1. When you get the hatch trim pull down a bit you can reach in with a long screw driver or a trim tool to help pop the trim retainers. There area couple that are pretty deep and take a bit or force to remove. This will help to keep them from breaking.
2. I used an 8mm socket to help depress the white plastic trim clips holding the rear bezel on. This helps to compress the tangs enough to be able to work them thru the hole without breaking any. A plastic trim tool and wood shims on the outside to apply some upward pressure helped keep things from popping back into place. There are 8 of those suckers.. and the most difficult ones are deep inside near the outer edges.
3. After replacement I checked the imagery and it was working, but was it missing the indicator bars. I could not find this anywhere on a google search whether or not it had to be programmed to the vehicle. I think it may depend on the vehicle options whether it is plug and play or you need to program it.. Well, on mine I needed to program it which consisted of going in with the scan tool and doing a LIM Module Activation. For my Autel scan tool it was under the Chassis service module (IIRC). I ran the LIM activation process, took about 20 seconds, power cycled the truck and checked the back-up camera... Indicators bars were back :)
Ford just issued a recall for this, but sadly my vehicle is not on the list.. The OE camera shipped was $80 and about 1 hour of time to swap out.
Anyway just wanted to share my experience and pay back a bit..
Glock
GlennSullivan
NY & FL
Hey Glock, did you happen to take some pictures that you could include?
Also, what model Autel do you have and does it cover the below listed vehicles. Looking to upgrade my scantool, but looking to confirm it will do 2 way ECM. BCM, Airbag System on all my vehicles. Recently had an airbag passenger seat presence issue and had to search around for someone who had a tool that could interact with it.
Ford Expedition Gen3 + Gen3A (2011 + 2017)
Chevy Tahoe GMT900 (2007 + 2013)
Dodge specifically Gen3 and Gen4 Viper - Does Stellantis access cost an additional yearly fee?
G
Glock_19_9mm
Florida
Hey GlennSullivan.
Sorry I did not take any pics. If you have ever removed trim it was not that difficult to get in there and then pretty straight forward to see what you have to remove. a quick youtube search should get you some pics of what needs to happen.
I was in the same boat as you where I had an older handheld scantool, but wanted/needed to get bi-directional capability. I ended up with the Autel MK808BT Pro.. https://www.autel.com/mk2/3228.jhtml I actually got it off AliExpress for a hundred bucks cheaper than Amazon.. I was a bit leery on ordering if from there but it was an overall pleasant experience.. And so far it has paid for itself in diagnostic work.
I have used it on Honda, Ford, Mercedes, Jeep and Hyundai.. So far I have not had any issues with anything I needed to do. I did a compatibility check for the Viper and it is in their list.. The devil is in the details on what exactly you have access to. The only thing I find difficult sometimes is knowing which modules to look under for functions.. If I had any negative comments it would be the manual is generic (100+ pages). so you have to either know what module controls what you are looking for or have some wicked google skills.
Glock
