ahammed akkif
any idea to increase drl brightness expedition platinum 2018
I believe you can in Forscan.
F-150 is a pretty similar platform and *most* mods carry over.
[URL I tried this but it doesn't work
Not working in expeditionI believe you can in Forscan.
Want some bright drlsHave they become dimmer than normal, or you just want some bright drls?
I think this is something you'll have to research and find out for the forum. I believe you're the first member to ask if they can be made brighter. I'm not so sure that the DRLs on the 2018-2021 expeditions can be made brighter. Perhaps on the 2022+ models, which may use code similar to the link to the F150 forum, provided above, but I don't think anyone has tried to do that on their 2022+ expeditions either.Want some bright drls
Can you share a photo of your vehicle's DRL. during the dayWould be cool if u could change the color too
Ok I will a little later today when I go out. Ill post on hereCan you share a photo of your vehicle's DRL. during the day
You previously posted this via a link… the OP tried it, it didn’t work… reposting it won’t change anything…Reading through the F-150 14G Forum, this should be the same, or close to it.
1. Revert/restore your changes in FORScan that you did for the above change via backup that you made to restore back to factory as-built values for line - BCM: 726-42-01 -> x2x2 xxxx xx--. Make sure to write and cycle your truck on/off.
2. Go into BCM as-built once again and create a backup once more, to be safe.
3. Change the following as-built with the following values. The preferred value that has been tested as of May 2022, is 4B (75%). Change only the "**" area, and leave the rest of the values in the line the way they are as default.
726-38-01 xxxx **xx xx--
64 =100%
5A = 90%
4B =75%
32 = 50%
19 = 25%
0A =10%
3. Write to the truck and cycle the truck on/off, a few seconds apart. Enjoy!
