Cam Phaser Replacement and Transmission Rebuild.
Jamaican Cruiser
Vienna, VA
Took my 2019 Expedition Max in today for routine service, a couple open recalls and what I thought were a few challenges:
  • Seeming Transmission Issue #1: There are many times a very pronounced delay in the transmission shifting to and from reverse, which can be 3-5 seconds. Very noticeable when trying to park on a busy street and sometimes there is a jolt when it finally goes into gear
  • Seeming Transmission Issue #2: At times when driving down the highway the transmission feels as if it has gone into neutral and the vehicles feels like it has no power. When you press the accelerator there is normally a loud and physical bang/thump as it appears to reengage the gears.
  • Seeming Transmission Issue #3: There are many times when the transmission simply bumps hard during upshift and downshifts while driving at normal speeds in traffic where the vehicle slows and then speeds up. This is happening with more and more frequency. One two occasions the traction control indicator on the dashboard lit up and stayed that way until the vehicle was stopped.
  • Cold Start Engine Noises: Lately the engine has been making rattling/tapping/grinding noises upon cold engine start. It has always made some noises on cold start, however these are louder, more pronounced and appears to last longer than normal.
The diagnosis is that I need Cam Phasers replaced and complete transmission rebuild. The vehicle only has 25,000 miles and luckily I purchased the 7 year/90+K mile warranty. They have to schedule the transmission rebuild and the earliest is January.
Has anyone else had to wait that long for a transmission rebuild? Ford must be having a transmission rebuild convention or something like that.
I am worried that this will taint the love I have for my Expy Max. It has been a really good family hauler.
After the transmission failed and was diagnosed in my 2015 Ford Expedition Limited 4x4 (purchased new - passenger use only), it took the Ford dealer three months to repair the transmission due to lack of parts from Ford..
Good luck. Your Expedition love will be tainted before this is over.
LazSlate
Arizona
The CAM Phasers are really the only big "known" issue on the Gen 3 engine. Once you get that fixed it should give you years and years of great performance.
2021 or 2022 is when they used the new parts on the new models.
Same with the 10R80
There are 2 Known Issues.
One is the clutch housing and the F Clutch. The housing teeth wear. Fords fix is a new anodized stronger housing.
The other is the CDF bushing slipping. Ford put a lip on it to fix it.
I believe these fixes are new and recently came out this year.
Once you get this fixed you will have a very reliable vehicle.
Example of known issues are I had a BMW 540 and everyone said there will be about 6 items that fail. (none terribly expensive). Low and behold I eventually got those issues in the first 80k miles. Once I fixed those the car literally went to 240k with no other issues.
Same with Ford. Those 3 are the big ones almost 100% guaranteed to happen. Cam Phasers pre 2022 (I think or 2021) and the 2 10R80 issues for all before 2024 and some 2024.
1111ExpyEL1111
NW Wisc.
Please, can you share with me (in a PM or however you choose) what those 6 issues were?
Russ16
Utah
My 2019 limited had cam phasers replaced at 30,000. Then the transmission was overhauled, replaced cdf drum at 38,000. I got the same old crappy cdf drum, now at 76,000 my transmission needs to be repaired again. My expy love is severely tainted.
mharwardt
Bakersfield, Ca
My 2019 Expedition XLT had cam phasers replaced. Next I got the dreaded wrench with shift sys fault service required message on the instrument panel. Took it in and they replaced a solenoid in the transmission. Picked it up and was occasionally hearing a clunk. Took it back in. They told me they were replacing the transmission (85,000 miles). Replaced it with a rebuilt one, didn't rebuild existing one. It has 3 year warranty or warranty until the end of my original extended warranty which is about the same time. Was told mileage doesn't count in this case. I love my Expedition but it's been in the shop a lot.
Rezolution
Pennsylvania
You don't need a complete transmission rebuilt. You just need a $30 plate replaced. The problem is it's about $1,100 labor to have the plate replaced. There is a TSB for it, it's called neutral out.That's the TSB they need to follow to repair your neutral out issues. I had the TSB done for the transmission, the cam phasers replaced, and then I had them replaced my thermostat as well because that never worked correctly either and Ford redid it. A good dealer won't charge you labor for doing the thermostat replacement, just parts because they have the whole engine torn apart anyway. Mine cost about $6,100 for all of the work listed above. It was worth it though because now I have a brand new car.
LazSlate
Arizona
I wish I could remember it was 10+ years ago and it was a 2000 540 so not sure if newer ones are fixed. Off the top of my head : Driver/Pass seat twisting, spedo dot matrix dots going out, coolant tank cracking. Wish I could remember more.
pheasantdog
Kansas City, MO
My 2018 (84k miles) just had its transmission replaced - but I couldn't wait on Ford. None of the dealers within 15 miles of me could even look at it let alone replace it within a reasonable time. All of them said they were at least a month out just to get me in to diagnose it. So I went to Certified Transmission. They drove it and dropped the pan and found metal pieces stuck to the magnet. Fortunately, I bought an extended warranty that covered all but a few hundred of the cost. Would have been nearly $8k otherwise.
Hellwig
Would you please tell me if the warranty is Ford ESP or a third party one?
rwbana
Utah
Regarding the "cold start engine noises", I was having the same issue and they told me the cam phasers needed to be replaced and were replaced under my warranty. Did it fix the problem...No. Took it back again with no new feedback. Took it in again a 3rd time and this time, they said it was something to do with the turbo and metal rods kocking the turbo assembly, and that it's normal under Ford's service bulletin. What a joke. Turbos making this clanking noises and nothing they are willing to do about it. Such an annoying noise.
GixxerJasen
DFW TX
Check this thread.
I still need to get around to installing mine.
Hillman 2-Pack 4-in Zinc-Plated Steel Window Screen Tension Springs in the Window Screen Tension Springs department at Lowes.com
Jamaican Cruiser
Jamaican Cruiser
Vienna, VA
Sorry was out of the country on a extended business trip. I have both the warranty under the Ford ESP and the Maintenance plan (both 6 year 90K miles).
The cam phasers were replaced and seems to be working well .. no more racket on start-up. However the transmission shop is backed-up until late January, and the symptoms seem to be getting more pronounced. I have suspended all long road trips until this is sorted. I was suppose to drive from the DC area to Miami this past week, but decided that was simply not a good idea given the state of the transmission.
BlakeMAX2019
Tran issue #2 there’s a TSB on it. We had the same issue with our 2019 at 30kmi. They call it a “Neutral Out” condition, complete loss of power on 3 occasions, one on a busy LA freeway at 70mph…pretty scary!
Also had the cam phaser issue like most. In addition, multiple heater lines cracked, they have plastic Y connections? Brilliant design! (Sarcasm)
Rear end rebuilt 2x’s. If you listen closely while coasting to a stop, you’ll hear a clunk at 20mph to 15mph. It’s a bad design and most people won’t notice, I’m a bit obsessive.
To answer your question, Yes, it takes that long to get the Transmission rebuild done. Mostly because the tech is backed up and Ford has major transmission issues. Coming from Toyota, the Ford service department is much different. At Ford, each tech has a specialty and at Toyota the techs do everything.
We meticulously maintain our MAX at the dealer but I also check all fluids regularly. I recommend everyone with a Expedition to do the same as you hopefully catch things before disaster.
I understand you concern about feeling tainted. We feel the same way, Its a strong family hauler however we are just waiting for the next thing to go wrong. It’s unfortunate!
SyndicateZ
Mass
Toyota dealers dont need specialty techs and everyone does everything because Toyotas rarely have major transmission/engine issues they need to work on. Most of their work is maintenance items or brakes
We see nee fords with less than 20k miles needing complete transmission teardowns and or engine rebuilds ridiculous
