The default volume setting in Sync3 is the volume setting at startup is the same as the volume setting at shut off, whether you shut the car off, then on, or shut the radio off, then on. If it's high when you shut off the vehicle, it will be high when you start the vehicle. Earlier firmware versions may have acted differently, but it's been that way prior to 3.4.23188. I've had my Platinum since 2023 and it's always been that way. I just don't remember what firmware version I had when purchased, (may have been 3.0 or 3.1), and have updated 4 times since.
