2017 Expedition EL Limited Front Park Sensor disablement
AMJET
PA
Hello!
I am new to FORScan but can sift through things fairly well. I bought the USB OBDLinkEX module, downloaded and registered the free FORScan and connected it up. My goal is to disable the front park sensor because inside the bumper the bracket is broken and it triggers the sensor every time I start driving the vehicle.
FORScan does detect the PAM module but when I go to configuration the PAM module isn't there to modify. Has anyone experienced this? Am I possibly doing something wrong?
Thanks!
07mustangman
tennessee
I have also looked at disabling the front sensors because I installed a bull bar. Couldn't find a way to disable them. I put some of the Velcro on the sensors that are behind the bull bar and that has stopped them from sensing the bar in the way. Can use the stickey pads for chair legs also.
rslynes
Wisconsin
Does your vehicle have the 'Type 3' Information Display Controls?
If so, you can turn off the front sensors under 'Settings' and then 'Front Park Aid' - check enabled or uncheck disabled.
