Need a favor, picture of crankcase pressure sensor connector 2020 Expedition.
JONWIC
I need a huge favor, can someone with a 2020 Expedition take a picture of the crankcase pressure sensor connector? It's on the driver's side under the engine cover. Wiring connector that plugs into the crankcase position sensor. I need to know the order of the wires left to right.
Three wires go into the wiring harness that clips into the connector. I am looking for connections left to right by wire color so I can get mine out back together correctly. Slaps at the shop put it back together after pulling it out during a repair. They are incompetent and I don't trust them to get it right.
Here is a picture of the wiring connector in question. Red X is on the censor.
Thank you in advance.
HazBeen
Great Lakes
The following images are also attached below as PDF documents...
Crankcase Pressure Sensor - Connector C1088 Pinout Diagram - 2020 Expedition.jpg
Good luck!
  • Crankcase Pressure Sensor - Wiring Diagram - 2020 Expedition.pdf
  • Crankcase Pressure Sensor - Connector C1088 Pinout Diagram - 2020 Expedition.pdf
