Build sheet / HD tow
Schmitty2005
Minnesota
Figured I would reach out here first:
Just wondering if anyone still has access to check/lookup build sheets? I recently purchased a '21 Expy with all the tellings of HD tow: trailer dial, brake, 3L rear end on the door card. Just want to have it cofirmed 100% from the build for piece of mind for myself, since you just never know, till you know.
1FMJU2AT5MEA79537
Thanks for the help!
Nathan S.
meder2487
Pittsburgh, PA
You should be able to contact a Ford dealer and they can print out the original window sticker for you and email it to you. This should tell you what you are looking for.
Fizzy
Alberta, Canada
Yup, HEAVY-DUTY TRAILER TOW PKG is in there.
  • 2fdc85e2-a298-4464-9b10-1685f8f9f3cc.pdf
rugedraw
Miami, FL
Window stoc
1FMJU2AT5MEA79537
Nathan S.
Are you able to set up Fordpass? It does not seem like your connectivity is working. Also, you show an APIM (touchscreen/infotaintment system) update pending. You can download the files and instructions to do it yourself here:
Fizzy
Alberta, Canada
huh, nothing about the radiator. has HD Tow of course. Doesn't mention CCD, which I'm almost certain I have?!?
Weird. I’ll run mine later and see what it says.
I’m getting those off a third party website, so they’re not official Ford monroney window stickers. Maybe it’s that, but they should be accurate.
Left Coast Geek
Mid Left Coast
I've been dealing with various vintage Mercedes for some years now, they have this thing called the 'data card' which is included with the vehicle, and also can be looked up via the VIN, the data card has a long list of 3 and 4 digit option codes, and throughout the parts catalog ("EPC" in Mercedes parlance), parts are indexed by the option codes they relate to. This is very handy for sorting out things on an older car.
Fizzy
Alberta, Canada
Audis have this too. Even modern ones. It’s fantastic for determining exactly what options are on the vehicle. It’s usually on a large sticker under the hood or in the trunk somewhere.
