6,000 lbs. or 9,000 lb. Towing?
Mack Ward
Kingwood, TX
Thw Ford Towing guide says I can tow up to 6,000 with my 2020 XLT based on my axle code but I have the class 5 hitch which says I can tow 9000. Which is correct?
M
Mack Ward
Kingwood, TX
I have the Class V hitch and the integrated brake controller. Does this mean I have the heavy duty tow package?
TheDoug
Mansfield, TX
That is a good question ... They all come with the hitch
Tow package includes 3.73 gears, upgraded radiator, brake controller, trailer backup assist knob.
If you are missing any of those you don't have it.
bb37
Member Relations Specialist
Indiana
All 2024 Expeditions came with a "Trailer Tow Prep Pack" that included a Class IV hitch receiver and a trailer wiring connector with 4- and 7-pin connections.
Do you have the window sticker, if so, you should see a line like this under Optional Equipment:
If you don't see that on your window sticker, you don't have the package.
Heavy-Duty Trailer Tow Package includes the following on XLTs. Other trim lines may be slightly different:
Calidad
This is a common question. Hitches are just hitches. The vehicle is the limiting factor in most cases. Even at 9000lbs the Heavy Tow version is pretty much a flat lander only hauler.
