Brushless Cooling Fan Update for 2020 Expedition MAX Limited?
scsulliv
Chicagoland Illinois, USA
I've got a 2020 Ford Expedition MAX Limited, and I use it to tow a 7x14 extra-tall v-nose enclosed trailer from time to time. The trailer is pretty light (around 4000 pounds loaded), but the aerodynamics are absolutely terrible, so any truck that I've pulled it with has really had to work on the highway. I had a 2014 Yukon XL with the 5.3L before my Expedition, and it absolutely struggled to pull this trailer, typically running between 4000 and 5000 RPM on the highway to maintain 65 to 70 MPH. The Expedition does much better, typically running between 2000 and 2600 RPM, with power to spare!
Anyway, I towed the trailer from Chicago to Northern Wisconsin earlier this year, ambient temperature was 75F or so, and I was getting coolant temps up to 235 - 240F on the coolant temp gauge pretty consistently on the highway.
So, I bought the thicker radiator and the higher-powered brushless cooling fans for Expeditions with the HD towing package.
The radiator installation was pretty straightforward (I had to modify the left sealing baffle a bit to make it work, but otherwise it was a drop-in).
However, the brushless fan install is more difficult. First, it uses 3-pin connectors vs. the brushed fan's 2-pin connectors. That's fine, I bought the right connectors.
But - looking at the factory wiring diagrams and comparing the wiring between brushed and brushless fans, things start to get tricky. So I left the 2-speed brushed fan in the truck for now while I try to figure out the wiring and fan cals on the brushless fans. FYI - The thicker radiator helped to improve the cooling performance quite a bit, but I still occasionally get coolant temps up to 235F or so on the gauge with the 2-speed brushed fans, so I'd still like to install the brushless fans if at all possible.
If you look at the wiring diagrams for brushed cooling fans (see the attached files), "LFC" from the PCM controls cooling fan relay 1, so I assume it's a ground signal.
However, for brushless fans, "LFC" from the PCM controls the PWM signal input to the fans. That means that some calibration in some module (probably the PCM) needs to change so that the output from LFC is changed from a ground signal to a PWM signal. As far as I can tell, the brushless fans have controllers built into them, so that all they require is 12V, ground, and a PWM signal in order to work. There are some other minor wiring changes required, too, but those modifications should be pretty straightforward (changes to some relay grounding).
The other part of the equation is that there are likely some fan cal tables that need to be modified to work with the brushless fans, too.
So the question is - does anyone know what calibration needs to change to enable a PWM signal at wire LFC from the PCM? And - is this something that can be modified with a ForScan tool or similar?
Also - is there anyone who has an Expedition with the brushless fans that can share their fan calibration tables? There should be fan cal tables for engine coolant temperature, A/C refrigerant head pressure, and probably transmission and engine oil temperatures as well. Possibly even for things like exhaust temperatures, too.
I'm having a hard time believing that I'm the only one that's tried to do this upgrade on my own. I found this info regarding F150 fan upgrade, but he had the same problem that I do, and no solution is presented: https://www.f150ecoboost.net/threads/2017-f150-fan-swap.83667/
Thanks!
FYI - I upgraded the entire cooling system on my 2014 Yukon XL, too, so this isn't my first rodeo. On that truck I installed the thicker factory radiator with built-in engine oil cooler, ran all of the engine oil cooler lines (with thermostatic controls) to the engine, added the factory auxiliary transmission oil cooler in front of the radiator in addition to the in-tank cooler, installed 900W fans (instead of the stock 700W fans), and had to install a bigger alternator in order to deal with the bigger power draw from the cooling fans. That made a massive difference in transmission temperatures on that truck while towing, and probably helped the coolant and engine oil temperatures out, too.
Rob6805
Do you have the updated thermostat?
S
scsulliv
I actually bought a new OEM thermostat from a Ford dealer based on what I read on this forum, but forgot to install it when I installed the HD radiator. I'll have to install it one of these days, but the hot coolant issue that I'm currently having while towing is definitely not caused by a thermostat that's stuck closed. It's worth a shot to try it out, though!
Separate question - where is everyone buying their 170F thermostats? Is this a Ford OEM part, or is it aftermarket?
Finally - if anyone cares, the standard radiator is 27mm thick, and the HD radiator is 32mm thick. Also, the driver-side plastic end-tank on the HD radiator is smaller and more contoured than the standard radiator, which likely explains why the HD radiator holds less coolant than the standard radiator.
Dice Roll
Craps Table
Don’t chase your tail on this, if you don’t have the new style stat, dont waste any time on anything else. My truck ran hot from day one and I thought that was normal, until the gauge started showing it was going crazy. New stat, way cooler.
lobsenza
I changed my thermostat and mine trans temp is about 18 degrees cooler while towing. I went 1 step cooler on the thermostat than the factory (I think it was 188 vs 195). I was concerned that going too cool on the thermostat might affect how the electronics respond.
I do have heavy duty cooling.
BMW2FORD
CT
Very easy. 3x 8mm screws hold it to the housing. You don’t even have to pull off the hose.
Fizzy
Alberta, Canada
I think this may be something I do later once the Premium Care ESP expires. It's at the dealership now having the transmission rebuilt. Whilst you know, and I know, and we all know, that the 180f stat means a cooler running transmission which means better longevity, the last thing I want to do is give Ford corporate any reason to deny another claim on the transmission based on using a non-designated part on the system cooling that transmission.
That stat part number lists many Ford vehicles, but the Expedition isn't one of them. While we all know it's 100% compatible, the bean-counting urchins at Ford corporate could very well use that as an excuse to slime their way out of paying.
I had my fingers burnt before on a similar situation (different manufacturer) and am definitely not looking to go through that again.
