2026 Tremor is worth it
Expensedition
Newport, RI
I finally took the plunge and traded in my beloved 2014 Ford Expedition Limited for a 2026 Tremor. My 2014 was the best vehicle that I ever owned since she never let me down. Some people thought I had bought a new vehicle when looking at the gleaming paint just weeks before I traded her in. My 2014 was a beast in fact that was her name "The Beast" with the 5.4 Triton engine, the last year for Triton, and mine was a gem, no issues, Mobil one from day one. I did hate to give up the power of knowing how to fix anything on my ride for the new networked based automated product we all must finally capitulate to buying but I knew that my 2014 could only last so long before body corrosion would be an issue.
The new 2026 Tremor is amazing, and honestly it didn't take long to get over all of the funky things they did to make it lets say non-organic: The shifter dial slightly out of reach (Damn I miss my grip shift where my right hand naturally fell as I sat in the driver seat), the strange almost aircraft type steering wheel that does not easily (at first) spin back to center as you loosen your grip, the all digital I/O where you have no gauges, very few if any indicator lamps and very few buttons or knobs, and the two touch pads on the steering wheel? WTF, but you get used to all of this, fast, and one thing that served to make all the unpleasant stuff fade away are the seats that are incredibly comfortable. Eventually, you get to realize the layout is near perfect, which took me three days to feel it.
So now I am going over the entire vehicle and looking for faults and prepping for preservation. Before I bought this truck I crawled under it in the showroom and found the good and the bad. In this post I will show you the first bad item. The brand new vehicle (11 miles) had scratches on the frame that look like manufacture or transport scratches in the paint. The scratches are located adjacent to the transfer case (see Fig.1) on both right and left sides. a similar set for scratches are found about four feet aft in the same area. Perhaps there is a gripper in the plant that holds the frame during assembly that has some rough surfaces on the clamps (Ford should address this). I have already cleaned, prepped and painted these marks since rust will take root fast on any bare steel.
Looking around under the Tremor, nearly everything is painted except for the driveshaft, front axles and engine/drivetrain parts (Differential is painted!). I am getting ready to undercoat my Tremor but first I have to paint the driveshaft and any other thing I may have missed.
My new "Beast version 2.0" is really growing on me. I will post more as time allows.
vintageman
Martinez, GA
Congratulations on the new ride. When I had a 2014, it was a pretty good one as well. I recently traded in my 2019 for a 2025 Active Max. It took a few days to get used to placement of controls as well as the shifter and the steering wheel but I did get used to it. Taking it on a long drive for work this weekend, opted to drive instead of flying because it only has 800 miles on it and I want to put a few more on it. Good luck with the 2026.
Tom
Expensedition
Expensedition
Newport, RI
Thanks Tom,
My 2014 was great but I did have a lot of factory unpainted parts in the undercarriage that rusted rapidly. I fixed most of that by replacing those parts with new powder coated parts and then coating with "Fluid Film". Although that was costly, it was rewarding to know that the elements (mostly road salt) would not be eating away at my ride.
This brand new Tremor needs to get all the protection I can give it ahead of the process of corrosion degradation. I hoped to get the undercarriage coated with fluid film before the it snowed but nature had other plans. I need to drive it today and I hope that I can undo whatever road salt makes its way into the frame. MY question now is: Do they E-coat the frames on expeditions? I need to open that question in a new post.
I did find out what the scratch marks are on the frame. When they stack and transport the frames they use ratchet straps (See photo) and I guess there was some grit embedded in the straps, again Ford QC.... can you get on that? Maybe I nit pick a little too much but I think we can get our moneys worth if we fill in the blanks on our own.
They made a great product, lets make it even better.....
Steve
Expensedition
Expensedition
Newport, RI
With the frame coating touched up, I am going to wash, desalt, dry and coat the undercarriage with fluid-film black today.
Nature always wins but I am a survivor and plan to fight this battle with the elements.
V/r
SM
whtbronco
Winchester, VA
Thanks for the details in the original post @Expensedition, some I was unaware of. I've been pondering replacing our 2004 Expedition EB.
I am looking forward to your corrosion protection process thread.
Fastcar
Army
FL
Kudo's to you with the job your undertaking. Don't know where in Newport you are but if near the ocean the salt will always win. I'm a few hundred feet from the beach and the salt is unstoppable. We run our Expy through a car wash that does the underneath every other day. Hopefully that will help to sustain it.
Good luck with it!!
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Well, congrats on the new ride, hope it will serve you well !
However, if I had seen those scratches on the frame before or at the time of purchase, I would have insisted that they be smoothed off, primed & undercoated as part of the deal..
but that's just me, cause when it comes to this kind of stuff, I am always a major, boot-yielding PITA and will either get what I want or I will go somewhere else... especially considering how much $$ they charge for these new vehicles nowadayz....
Expensedition
Expensedition
Newport, RI
I am also the biggest PITA when it comes to buying a new car/truck (I walk out of many dealerships without saying goodbye).
I found these scratches when I crawled under it on the showroom floor. You have to realize that the dealer is not going to do what you want, they will do what they can and that is almost always not what you wanted, leaving you more frustrated, taking away the Joy of the sale and ownership. The quicker that I could get the truck into my hands the better it would be.
I guess I learned many years ago never to trust another person to change the oil in my baby so, well, I own it and I will care for it.
At this point I am more concerned about the galvanic battery that I just bought. I treated these scratch marks the day that I bought the truck.
More to come.
V/r
SM
Moeman
Greenville, SC
I don't think ratchet straps created those scratches - they wouldn't be down the entire rail top to bottom like that, more just at the edge. You're probably correct about a piece of equipment in the plant. I was involved in the transfer of Exp to KY Truck plant way back in the day and I can think of one piece of automation that may have done it if they're not keeping up with replacing the UHMW pads.
As much as we tried to protect the e-coat, just was not possible to be perfect. You have steel pins going into various frame holes to fixture the vehicle or automation, there are steel spacers that separate the frames during shipping. Good for you doing the touch-ups. I tend to do the same - every once in a while get under there with a rattle can and hit some of the bare spots.
Expensedition
Expensedition
Newport, RI
Moeman,
Thank you very much for the feedback on this. I am familiar with jigs and fixtures and appreciate you helping to validate my original premise. There must be some grit embedded in the poly of those pads (come on Ford, change these out with new). The image with the straps was all I could find image wise to base that theory.
I also appreciate you validating that they do still E-coat these frames.
V/r
SM
Expensedition
Expensedition
Newport, RI
I just changed my oil, and had a good look at the undercarriage after some miles. All looks good so far.
SM
Saif
Dubai
I Just received my 25 tremor in UAE.
Firts thing i did is check those markings and they are there.
Asked the dealership and they had no clue on what they are and how to repair them.
They took a note of it and said they will get a solution sorted in my first service check up.
Expensedition
Expensedition
Newport, RI
Saif,
Thank you for validating the issue with such a random sample (Purchased in the UAE). I am pretty sure that they all come from the same plant in Kentucky so maybe we can get something done about this.
V/r
SM
kyjd75
central Kentucky
Thanks Tom,
Steve
Those frames are made in Elizabethtown, Ky., by Metalsa. 2000 employees, they run 24/7 making those things. Most are shipped out via rail, but some are transport via truck as well. I live only a couple of miles from that plant, so pretty familiar with it.
Expensedition
Expensedition
Newport, RI
@kyjd75
Most people don't realize how many things are farmed out.
I was just in Singapore and looked at a BYD Sealion, I saw some very familiar parts on the hinges as I opened the door.
As a young gearhead I recall looking at the little carriage symbol for "Fisher Bodies" on GM cars.
Nothing new I guess.
SM
