My 2020 Expedition with 60000 miles is going through coolant. The fan came on and was running at super speed. I check the coolant level. The reservoir was empty. I put a half gallon of Motorcraft coolant to get it between min and max. The fan went back to normal speed. Less than a week later same thing. Coolant was low. I don't see any leaks. I borrowed a pressure tester hooked it up after refilling the reservoir. I'd pump but it wouldn't hold and pressure. Still I see no leaks or hear any hissing. I checked the oil. Oil is fine and not milky. I tested the test kit on another car, no problem ai I know it's not the test kit. I don't feel any air escaping out of the cap. Tomorrow I'm going to take the engine cover off the top of the motor so I can see the heater hoses better.
Any suggestion?
Thanks
Any suggestion?
Thanks
