DTC Code P1131
falcn
Pittsburgh PA
Tonight when driving home from work my 1997 Expy Eddie Bauer with 5.4L check engine light came on.
I noticed no change in performance - no shuddering, hesitation, etc.
I went to Autozone and borrowed the code reader and the code pulled was P1131.
Where would you start on the list below?
Or should I just replace the HO2S-11 Oxygen sensor?
We just got the vehicle on Dec. 1st - 73K miles on it now.
This link shows:
http://v8sho.com/SHO/TSB0197HO2SServiceTips.htm
"P1131 - Lack of HO2S-11 Switch, Indicates Lean
When an HO2S sensor indicates lean at the end of a test, the system is trying to correct for an over-lean condition. The code is set when the fuel control system no longer detects switching for a calibrated amount of time.
See Possible Causes for DTC P1130"
Possible Causes:
Electrical:
· Short to VPWR or VREF in harness or HO2S
· HO2S circuit shorted to Ground
· Water in harness connector
· Open circuit
· Corrosion or poor mating terminals and wiring
· Damaged HO2S
· Damaged PCM (other DTCs should be present)
Fuel System:
· Excessive fuel pressure (stuck fuel pressure regulator, restricted fuel return lines, etc.)
· Leaking/contaminated fuel injectors or fuel pressure regulator
· Low fuel pressure or running out of fuel (fuel pump concern, fuel supply line restrictions, low fuel level, etc.)
· Vapor recovery system (stuck VMV, etc.)
Induction System:
· MAF contamination
· Air leaks between MAF and throttle plate
· PCV system / Other vacuum leaks
· Improperly seated engine oil dipstick
EGR System:
· Leaking gasket
· Stuck EGR valve / Leaking diaphragm or EVR
Base Engine:
· Oil overfill
· Incorrect cylinder compression
· Exhaust leaks before or near the HO2S
· Secondary air stuck on
JUST4FUN
Admin
Moderator Administrator
Il
i would replace fuel filter first and go from there
F
falcn
Pittsburgh PA
I cleaned the MAF sensor wires - cleared the codes - no more CEL - and it is running better and gets better mileage.
tarafied1
Western Kentucky
I know this is an old topic but I thought it would be good for those who are serching.
I have had lots of codes recently on my 2000 EB with the 5.4 V8.
I changed the DPFE sensor for insufficient flow at the EGR. It didn't help. I pulled the throttle body and intake and cleaned it, changed EGR and then got the p1131 code. I cleaned the MAF with some spray and have had no more issues.
monicacorzo
san antonio
Expedition 03
I have the same trouble with my expedition, I replaced the fuel pump and filter also the fuse box because the fuel pump relay inside wasn't working, runs better but still make like a little jump. Then I replace the spark plugs, coil boots they had rust and looks like tartar was building in... runs better but still does a little jump it feels less than before but I don't know what else to check still getting the same code P1131
