In reference to a transmission fluid flush and refill seeing as how there is no dipstick to check the level yourself
Point being made is most on here could research the best way to do a procedure and then be certain they DID do it right as opposed to hoping the flunky who happens to be the one working on yours is having a good day, has more than 2 months experience, is in a good mood, likes his job, cares about doing a good job, treats every vehicle like his own....
Good luck with all that.
The way it often works is the newest flunky gets to do tires and/or oil changes. If they don't strip out too many drain plugs or cross thread too many oil filters then they get to progress into transmission flushes.
Not going to get the Master Tech with 15 + years experience doing heads and timing chains and cam phasers over there to flush a trans.
