2019 Expy Forscan
bushpilot
Houston, Tx
BdyCM 726-27-01 xxxx xxx0 xxxx Enable Fogs On w/ LED headlamps
yeah I tried that one ....and it didn't turn Bambi on (that sounds weird as I type it.
my 2020 was set to 0001 1401 026D and I changed it to 0001 1400 026D w/ no results.
wakeboarder
Fort Lauderdale, FL
Lou Hamilton
Maryland
Im not having any luck w/ the double horn honk when key not present either.
What setting did you use? I know you have the 2020, but I used the following on my 2019 with success:
BCM 726-41-02 xxx0 xxxx xxxx
My default stock setting was 0001 0101 0174.
bushpilot
Houston, Tx
Lou -
Ive tried several diff options including "plain english" none have been successful.
CGETX20
East TX
Good evening folks. I'm new here but I've been doing a lot of research before trying this out myself. I've gotten my ODB2 connector (Veepeak brand), purchased a Forscan license, and started playing with the plain English/easy mods on my 2020 Max XLT. For some reason, I'm connecting up fine and everything looks to be working, writing changes shows to work in Forscan, but only one (heated/cooled seat buttons on home screen) has actually worked. They just don't seem to take. I'm following all the steps as explained in all the forums and videos. Another odd thing is within some of the modules I show some things as "disabled" that I know are working (like remote start). I'm to the point of thinking any updates will have to be done through the As-Built codes, and that we'll have to wait until a new spreadsheet comes out that is applicable to newer Expeds. As some others have mentioned, the codes in the F150 spreadsheet don't line up with what I'm showing for the 20 Exped. Does anyone know how the Forscan group works well enough to know if they are working on this currently? I'm wondering if it should be pushed with Forscan support or if they're on it. Thoughts?
Tracy Cook
CO
Unfortunately, I don't think the forscan guys are going to work on lining what the values need to be. Looks like the 20MY Expy did get different values, my guess is that maybe the 21MY F150's will start to see it, and someone smarter than me will figure them out - there will be far more MY F150 purchases than 20MY Expy, so just waiting.
I did notice that trying to write anything to the BCM settings will fail. I've sent a message to the forscan dev's to see if they know anything about that - hopefully it will get addressed at some point. Looks like it took a few years for them to address writing IPC settings when the 18MY was released.
To enable heated/cooled seats on the home screen - use this setting, it's worked on mine, and I have a 20MY.
APIM 7D0-01-01 xxxx xxxx xExx - heated/Cooled seats, HSW, Rear Controls on Sync Screen
LokiWolf
Super Moderator
Super Moderator
Richmond VA
Why are we discussing 2020 Exp FORSCAN Settings in a Thread called "2019 Expy Forscan"?
We aren't even discussing it in the 4th Gen FORSCAN Thread.
If you read that from earlier today or last night, you would see there is a dev build that lets you write to the BCM in the 2020. I have spent an hour today trying to test settings. The BCM in the 2020 addressing is NOT the same. Nothing works. I stumbled across one thing that did, but it was a previous change I was trying. I think I can map it out, but I need to compare the 2019 file that Wakeboarder sent me line for line...and see if I can find the patterns & similarities.
CGETX20
East TX
My apologies LokiWolf, I appreciate the feedback from you and Tracy Cook. I'm new here and while reading this thread saw some questions about 2020's, and posts from people that show to own 2020's, so I wrote it here hoping to find help from the right folks.
Sounds like we're in a waiting game now. I'll try to follow in the 4th Gen thread.
