Short Circuit?
gotaneye4it
usa
Hello, I have an 2003 Ford Expedition Eddie Bauer edition 5.4 liter engine. My battery failed so I bought another one. I put it in, cranked it, and it ran smooth.
The next day I awoke and got ready for work, went outside to crank it, and no start. I was told it’s possibly a faulty alternator, so I replaced it. I cranked it up no problem as I let it run for awhile.
I took it on the road brought it home no problem. A couple of hours later I took it to get something to eat and instantly I start to smell smoke like something was burning. I didn’t see any smoke to know where it was coming from, so I got it home, looked under the hood and no damage.
I then looked in the back where my after market equipment is and no damage. I start sniffing where my speakers are in the car and no damage.
I then open the glove and bingo the smell is coming from behind my glove compartment. Can anybody tell me what it might be before I take it into a shop to be possibly taken advantage of?
( no engine lights or charging system failure warning )
whtbronco
Winchester, VA
I would scan it first, always a good place to start. That said it's common for 2003 and 2004 models to have the fuel pump relay burn/melt. It's behind the passenger front kick panel and could easily seem to be coming from the glove box.
Pull the kick plate trim and then the kick panel, pull the cover off the fuse box and if you'll smell it really strong if that's the case. It can be replaced fairly cheap and easy or you can buy a replacement fuse box, aka Central Junction Box.
This sticky thread has lots of info on this issue:
GaryH
Drat. Another thing for me to worry about on my '03.
Hamfisted
Ft Lauderdale
The only thing directly behind the glovebox that might smoke is the AC blower and it's speed resistor or that harness plug to the resistor. But I don't know how your "aftermarket equipment" is wired in.
Does your AC blower still function normally ? All speeds available ?
Vincent Vega
Huntington Beach, CA
Yeah, no factory wiring is behind the glove box, but you might have smoke going through there because there are HVAC ducts, heater core, and blend doors behind there. That means that smoke originating from somehwere else may have been blowing into the cab from those ducts. Or smoking electrical from the kick panel area (where the fuses are) was migrating through the glove box.
I recommend a close visual inspection of the wiring under the hood, and of the fuses and relays located behind the passenger side kick panel. Look closely for burn marks. Could be a short, or maybe someone wired in your aftermarket stuff without fuses, which would cause burning and heat buildup in the wiring. Aftermarket wiring is rarely done right. These trucks will burn out fuel pump relays sometimes but won't usually go up in smoke the way you are describing. Let us know what you find out.
badbolr
