G
Guest
i was rear ended as i was going 60 mph on the freeway by someone going 100 mph. my rear bumper and hitch was pushed down a foot and bent the frame down where it all connects. it also buckled the left and right back qrts and bent the body down a bit where it buckledthe qrts. it was a brutal hit on me and then i was hit by anothewr vehicle in the drivers door at 60. lucky i was in such a big vehicle. i hope its not totalled but i dont know if the frame end can be bent back to normal to re-attatch everything. both the back doors open and close fine, with only a slight tight fit on the passenger one, altho both doors dont line up at the bottom (the door sticks out now). looking underneath, there is what appears to be a long black fuel pump tucked up under a frame rail on left side. it brokethe bracket and shiftedthe pump up and squished the wriing but its not leaking. the fule pump shutoff ddnt trip either which surprised me. i did drive it home and all seems to be well cept for the alaignment is off from spinning donuts 3 times at 60 mph (AND IT DIDNT FLIP OVER!)
