toddster911
hello, new to forum, just picked up an 03 xlt with 4wd. here is the problem...when in 2wd can turn left and right no problem and under normal acceleration at about 35-40 mph and I let off the gas , then touch and go with the gas lightly it seems to whine out the driverside front....then when I stop and put it in 4wd hi and try and turn (normal corner radius) it slows right down and if I turn a little more, it will stop the truck all together if I am not pressing the gas.
Now is this a outter wheel hub problem? do they have locking hubs?
Or a axel shaft problem (boots look great)?
Or a clutch or motor mechanism in the t-case?
again the binding only happens in 4wd hi or lo
I would really appreciate a quick response as if the problem is too great (new t-case etc) ...I would rather return it to the buyer...although it has low miles and is as clean as showroom...so you understand I would rather fix it.
thanks to all who chime in!
Todd
Todd
