03 Expy Rear A/C Clicking Noise
Stearman
High All, new to the forum but I do alot of work on my vehicles. I have an annoying problem with the rear AC on my 03 Expy. It has started cklicking...loudly when the rear AC temp is set to cool and clicks more softly to none when the temp is warmed up. Has anyone else experienced this problem. It occurs when the AC is on and when it is off. I have looked way back in this forum for any similar problems and found one from quite awhile ago with no response. Thought I would try it again and see if this proble is becoming more common. Your help is appreciated Thanks!
smo0othride
San Diego, CA
That sounds kind of like the problem I've been having, except I'm thinking mine has to do with the rear heat instead of the a/c. Where exactly is the noise comming from on yours?
S
Stearman
I agree Smoothride, it is probably more associated with the Heat. It is coming from the passenger rear side of the vehicle. It is back where the rear AC system is located. The clicking will get really soft if you adjust the temp control correctly ( whatever that happens to be that day) and will get really loud when it is not adjusted correctly! I was told that yu could pop offf the top of the rear passwenger side panel and there were two white heater actuators back there. If you unplug one of the acutators and the noise quits you ahve a bad actuator. I am going to try this remedy this weekend.
smo0othride
San Diego, CA
Let me know how that works out, I might try it too so I don't have to spend money on a diagnostic at the dealership.
G
Guest
Clicking Rear A/C
I think I know exactly what you're talking about. It happened to my '03 Expedition... three times. I first noticed it when I went to switch the rear A/C from panel to floor. A clicking started from the cargo area. The blend door was stuck. The dealer replaced it under warranty. 5,000 miles later, the same blend door went out again. Dealer replaced it. The third time, I went to move the temperature switch from cool to neutral. The clicking started again. Only this time, I was 1,000 miles past the factory warranty. The dealer determined that it was the temperature blend door this time and replaced it under their "good faith" warranty program. I lucked out because they said the repair would have been $80 for the blend door and $420 for the labor (they have to disconnect cooling lines, remove the rear A/C system from the truck and take it apart to reach the blend and vent doors.
If you hear the clicking when either the blend door or vent door is in a certain setting or position, but stops when you turn the dial or control another way, you can be fairly certain that the problem is a faulty blend or vent door.
SPLFTW
alberta
My 03 just started this today. T.T I think I'm just going to take it all out (I'm building a huge sub box back ther anyway) but will it send of a check engine light because I'm ******* with the cooling system ( I don't think it will but I want to be sher) any incite would be nice.
WHOISMOOTOO
Dallas, TX
I had this same problem on my 05 its the control valve that changes roof air to floor air for the rear i unhooked the wire that goes to the unit from the top and it blows just out of the roof now, havent had a problem since, theres lots of room for a sub on the other side
chilli bullitt
Chillicothe, OH
Our '03 with 130,*** miles just started doing it this year. Will have to take it apart to see what it is. At least now i have a starting point and know what to look for.
