The heat shield seems very tight. It sounds like it's coming from inside the catalytic converter. (I think that's what it is...)Welcome!!!!!!
is that the heat shield? when it cools.. can you move anything even just a small wiggle? sometimes it seems tight but the heat will loosen it.. i had oil pan gasket replaced and cross member is loose just enough to rattle at certain rpms or speeds... so i just blow by that section on the speedo!!also..have any work done recently???
