'05 running like crap
DAMN_FORD
My 05 is falling on it's face at low speeds. Running poorly, no power (Less than the usual no power) We have it at the dealer. The service monkey's are doing the part replacement shuffle trying to figure out what it is. First the throttle pos sensor, now the throttle body. Anyone have this problem yet?
Thanks!
monsta
Big Island of Hawaii
Have they reflashed the PCM?
Early 3V 5.4L needed a reflash for poor throttle response. Maybe the sam eis holding true for "early" Expys with the 3V 5.4L as it was for early F150s.
I haven't heard of this problem in the Expys...till now. :)
D
DAMN_FORD
They called and said it was mis firing on #3. Now they are saying its the Transmission. They said it was shifting 1,2,3,4 immediately. Sounds like they don't have a clue. Comforting.
Why does this always happen to my vehicles when I bring them to dealer service?
I will look for TSB on reflash.
Thanks!
D
DAMN_FORD
'TWAS A BROKEN CHECK BALL IN THE VALVE BODY OF THE TRANSMISSION.
WE WILL SEE HOW SHE RUNS NOW.
D
DAMN_FORD
9K miles.
It sounds like a freak deal. Defective check ball. You wouldn't expect that part to fail unless it was cracked during fabrication.
I must say other than this, this truck has behaved so far. We had far more problems with the '03. My only complaint is that I wish it had more romp. It's better than the 2V, but still not enough. I thinking of a cat back now.
stang99x
I know there was a TSB on the F150 for those problems. Sucks with that issue though, its a tough one to figure out. If your gonna go with an exhaust, don't do it the crappy way. Build yourself a good exhaust. It might cost a little more, but you'll be alot happier in the long run.
http://navigatorfourms.7.forumer.com/viewtopic.php?t=4
There is a picture of part of my system there. Its a true dual 3 inch with flowmasters
