09 Expy EL Vacuum loss to power brake booster at speed
11b4v
Alabama
All,
2009 Ford Expedition EL. Replaced both the power brake booster and master cylinder recently; master cylinder was leaking into the booster. Before, and after, at highway speed, or on/after heavy acceleration, I lose vacuum boost to the brake booster and experience a hard brake pedal.
Any suggestions as to what part of the vacuum system is the culprit?
Much thank in advance for your assistance,
docraymund
philippines
If there are no vacuum leaks present and the hoses are tight you may have bought a defective master cylinder or booster.
11b4v
Alabama
I'm thinking the new booster is good, I'm thinking either a vacuum line check valve(s) or maybe a leaking hose that goes at speed/higher pressures.
The Swagonmaster
High Point, NC
There is always a vacuum check valve in the booster vacuum line to prevent exactly what you are describing. Check it to be sure that the vacuum that is there at idle (which is high) is still there when you open the throttle (when vacuum is low).
