16 inch wheels
nvycrmn
Springville, IA
yes, i was running 16x10 wheels with 365/65/16 toyos. those are my spare tires now but yes.
KWT2000
NINE MILE FALLS
cost was the main factor for me 17's with 35's would of pushed me over $1600 i got what i have for $1200
Y
yammerslammer
NKY
I found a set of rims I like, and there is a $50 difference between 16in and 17in(per rim). $200 will almost buy 2 new tires.
panda24619
San Diego
i have 16s. just make sure you make sure theres enough break clearance for the breaks. but my 16s came from the factory.
Poppa Wheelie
Beaverton
The only reason I am rocking the phony beadlocks is that the least expensive black steel wheels hit my front calipers. These are the second least expensive ones that fit. Also, if you're planning on bigger tires, you'll want wider wheels. Big wide tires look funny on skinny stock width wheels.
fiveohpoepoe
NC
I have always run 16x10,s on my Expeditions[except the 04]
jeff1998
Highland, IL USA
I am running 16x8 Mickey Thompson Classic II's with 285/75's on my 98. The rims fit perfect and clear everything. I did the torsion bar crank up front and a 3" spacer in rear. It sits level now and has gotten rid of the grocery-getter look.
