1997 Expedition Broken Front Shock Mounting Bracket
tinkering
Alberta Canada
1997 Expedition.
The front shock mounting bracket is welded to the frame. The top of the shock came free of the bracket when a piece of the bracket broke off. Is there an aftermarket bracket available to either bolt on or weld on to the frame, or do I have to fashion a piece to repair the original?
riphip
Memphis, TN.
I would fashion/weld into the existing bracket with at least 3/16" plate. Must have made a lot of noise over the years not to notice it earlier. MIG it if possible, won't be as hard on existing metal as arc weld.
tinkering
tinkering
Alberta Canada
I worked on it today, and saw your reply afterwards. I
fabricated a piece of 1/8" strap to fit the missing section. I migged it into place. I looked all around the shop and couldn't find any 3/16". I welded up some other cracks too. I hope it holds. I would have felt better with the 3/16" but I hope it will last like this. I was thinking of welding a 2 1/2" x 1/8" washer over the hole to beef it all up but decided not to; Still might.
You are right, this problem has been some time in the making. The shocks are pooched. For starters I have ordered some shocks and a swaybar link kit.
Thanks for getting back.
tinkering
tinkering
Alberta Canada
I would use 2. 1 on bottom and top if possible. Good job :cheers:
2 washers you mean? It would be real hard to weld underneath/inside that shock mount.
Would you consider using
the washers without welding them, or weld the top one, but not the bottom one?
