Bowesmobile
Nice work on the shroud! Looks good!
So last night I was very hopeful to finish my install. But I ran into a few problems.
The first problem is the trans. lines. If you have a 1997 and you order the radiator in the link I posted. You will need an adapter to up-size the trans lines. On 1998 and later (I believe) they used a 3/8" line which would be a 5/8"" fitting. The older 1997's used a 3/8" line with a 1/2" fitting. But I have not been able to confirm that. It should be a simple adapter from one size to another. I'll find out more after my trip to the parts store. If anyone has good information on these sizes I would really appreciate knowing them before I go into the parts store tonight.
The second problem I came across is this. In my research for this I came across this thread http://www.expeditionforum.com/f42/e-fan-16738/ and in post #14 it is said that there is a 3/8" NPT port on the drivers side trans flange. My 1997 does not have this. There were two ports I found. One directly under the motor mount drivers side, and one on the back of the head drivers side. I could see them but could not get a wrench into those locations to use them. My solution is much more simple. The intake has two sensors in the coolant path on the left side. The furthest left one is 3/8" NPT. I am going to Lowes and buying these parts. (1) 3/8" NPT brass pipe fitting Shop Watts 3/8-in Brass Pipe Fitting at Lowes.com and one 3/8" NPT brass tee Shop Watts 3/8-in Brass Pipe Fitting at Lowes.com. This puts the switches in the same port and give place for both. Plus that cooling path is right before it goes into the radiator. I my opinion its a good place to read temps from for my switch. I may have to add a grounding band. But we'll see.
So now this bumps up my cost roughly $15. Hopefully this helps someone else.
