1998 Expedition Air Suspension Issues
gt350ed
So-Cal
Howdy! I used the Search tool to no avail. I have a 1998 Expedition 4x4 automatic with air suspension. I've owned it since 2003. I absolutely love this car. It has about 145,000 miles. Several years ago, I replaced the rear bags. Have not had any issues since. However, for quite some time the air compressor has been much louder than typical. I figured it was going to need replacement, but it has always done the job, so I put up with it.
A few weeks ago, I was visiting my local tire shop. When I started the car to leave, the compressor started doing its job and within a few seconds, I heard all kinds of racket from the right front where the compressor is located and then nothing. It sounded like the compressor blew up, threw a rod in the little motor or whatever.
I drove home and it held air in the suspension UNTIL I disconnected the dryer from the compressor. Then the rear sagged. I removed the compressor and jumped the wires. It seems to have seized. No surprise. So, I ordered a used one off of eBay from a company that guarantees their products. When I installed it and plugged it in, nothing happened. Both the small "air suspension" fuse under the dash AND the HUGE fuse in the Power Distribution Box under the hood appear to be fine. So, then I jumped the eBay compressor and it seems to spin the electric motor fine. Not sure if anything else is supposed to happen by just jumping the hot and ground leads.
So then, I bought a replacement relay USED. Thats the bat-shaped piece mounted under the right headlight. It too is guaranteed to have been tested and working. I installed it today, NOTHING. The "Suspension" switch down by the passenger kick panel is turned on, but when I start the car, the compressor does not come on. Its as if juice is not getting to the compressor.
HELP!! Any ideas?
Thanks.
Ed
G
gt350ed
So-Cal
Bump! No help here? No experience in this subject? Have I posted in the wrong area?
Thanks.
G
gt350ed
So-Cal
Does the installed compressor run with the relay bypassed?
I assume you mean to "bypass" it to see if the relay is the problem. Not sure how to do that. Electrical is not necessarily my strong suit.
I DID jump the compressor heavy red and black leads to the battery and the compressor ran. Or at least the electrical motor attached to the piston/rod "compressor" portion ran. Not sure if both portions were supposed to do something with this type of "jump". The other two smaller leads were not part of the jump. I don't know what they do.
BAD RONALD
Fairfield CT
With the compressor installed, unplug the relay and jump lead contacts with a stout wire (bypassing the relay) to see if the compressor activates and raises the ass end of the truck. This worked for me and told me the OEM relay on my '01 was bad.
Be aware that the doors on the truck need to closed for the air ride system to activate.
G
gt350ed
So-Cal
I apologize for my ignorance, but when you say "unplug the relay and jump lead contacts", I don't know what that means, nor do I know WHICH lead contacts you are referring to. The wire plug going into the relay "contacts" 3 or 4 leads. I cannot recall, and I don't have it in front of me. Am I misunderstanding what you are saying?
G
gt350ed
So-Cal
Yes, the relay DOES have "A,B,C,D". I will check out the link you have provided, proceed and then report back. Thank you so much.
Your relay needs to show four pins labelled A,B,C,D for my advice to be any good.
The compressor harness plugs into the relay. Unplug the harness, locate harness side contacts "A" and "B", read post #2 in the link and follow diagram "Check Air Compressor Relay"
97 Exp Air suspension question ? - Ford Truck Enthusiasts Forums
G
gt350ed
So-Cal
I wanted to report back and thank Bad Ron for his assistance in trying to solve my air suspension issues. Unfortunately or fortunately, depending on your point-of-view, for me reality set in. I got to thinking that although I LOVE my Expedition, I cannot ignore that it is a 17 year old truck at this point. And, as relates to the air suspension system, it is quite realistic to assume that I may be chasing more than just a compressor and relay. If not now, most likely SOON.
So, I did a fair amount of research on making the conversion from "air" to standard springs and shocks. As one person put it, you can buy an entire conversion kit for the price of just one ride height sensor. Not having actually checked the price of a sensor, I'm nevertheless of the opinion that he is correct.
Today, I took delivery of a Monroe kit which includes rear springs, rear shocks and front coilover shocks. The entire cost was $227.00, INCLUDING sales tax. Shipping was free. Having read MANY reviews of this particular kit, including from those that installed it on the same exact year and model of Expedition that I have, I can't help but be a happy camper. The Expedition is backed into my garage ready for the conversion. Having reviewed a video of the entire process, I don't expect any issues relating to the install
Bedrck47
Elizebethtown, PA
Ed Just a curious question. In your original post you say
" Both the small "air suspension" fuse under the dash AND the HUGE fuse in the Power Distribution Box under the hood appear to be fine."
Just how did you test them??
z168
Cali
sounds like a relay. but I agree with the OP that if hes looking to keep the truck long term, springs are the way to go.
My replacement of the bag has held for 3years now. I also have another spare pair of bags and a reman compressor already in my garage once my stock one fails. I get a kick out of seeing the ass end level when I haul heavy items
G
gt350ed
So-Cal
Howdy! I didn't test them. I only visually checked them and determined they had not blown. Could they have failed without necessarily showing evidence? Maybe, but not likely. Everything worked until the compressor blew.
G
gt350ed
So-Cal
I was SURE it was a relay. But I replaced it with one that had been tested and still nothing was working. As I mentioned, I made the decision to give up on the air suspension system. Not because I don 't like it. I loved it. But in considering the age of the truck, and the age of the components, it was an easy decision to make. I just could not justify pouring a significant amount of money into a 19 year old system. As I removed the rear air bags, I recalled that I replaced those nearly 10 years ago.
Earlier today, I finished the install of the conversion to springs and shocks. And, although this is a job in which putting it on a lift would have made things a LOT easier, it was pretty straight forward. If you follow the Strutmasters video, you can't go wrong. And, at least in my case, I don't feel guilty, since my rear bags came from Strutmasters. I'm happy with the result and my test drive.
Hit By Thunder
Alberta
Switched my wore out system to new rear springs, new rear socks which are same with or without air ride, but the front shocks I ordered Pro-Comps for 6" lift. The reason for the 6" lift ones is the fullextended length of the front air shock has to be the same as any after market shock going in. Because the Expy I have is 4x4 and has the torsion bar front suspension, I did not need the coil overs for the front. Hope this info help out for all its worth.
G
gt350ed
So-Cal
I guess I'm not following. In my case, I have Monroe FRONT coilovers as part of a kit SPECICALLY for the 1998 Expedition 4x4 conversion from air suspension. Had I ordered the 1998 Expedition 4x4 conversion kit from Strutmasters, their's also include coilovers as a replacement (conversion) from air suspension.
Different strokes for different folks?
Hit By Thunder
Alberta
I cant understand why they would use coilover shocks for the 4x4 suspension. 4x4 suspension uses the torsion bars. Same set up as my 2001 f150 7700. No coil over shocks. I saw the Munroe kit as well as the Stutmasters. The coilovers would raise the suspension but the torsion bars are adjustable to raise as well.
All in all. I think you will be very happy with converting over. Ride is way better for sure.:cheers:
oldschool59
rolesville
We ordered the Monroe Conversion Kit for my sons 1999 2X4 Eddie Bauer Expedition. It took 6 hours to install it. There was no lift available. The rears went in with no problem but the fronts were another matter. Nevertheless all went accordingly and it now rides like a new one. The question we have is how do we disable the dummy light that now shows a Suspension Warning?
Thanks this forum has saved us over a grand easy. Total costs to replace the suspension was 197.00 including shipping from PartsGeek.Com
BAD RONALD
Fairfield CT
... The question we have is how do we disable the dummy light that now shows a Suspension Warning?...
...duuno... Black paint?
I've seen this question asked many times. Can't remember a verified resolution for a 1st Gen Expedition.
Try reaching out to the manufacturer of the conversion kit you purchased. They likely have been asked the question as often as anybody. Good luck.
Tuner710
Tacoma Washington
Sooter6 had a post showing exactly how to disable the light. Involves cutting wire or wires under the dash, worked for mine. Try a search on this forum. Good luck
american steel
delaware
HELP!! Any ideas?
Thanks.
Ed
any luck?
