josh1095
big matt: in 99 they got rid of the front vac hub system. they are permanently locked. it used a torque on demand system that, from what i gather is activated automatically when the pulses from the front and rear d shafts start to mismatch. it detects the rear slipping and engages clutch for front power. its an overly complicated system lol. i would be happy with 2hi and 4lo. straight forward and dirt simple. the truck was hit in the rear pass side and theres a good chance they replaced the rear from 3.55 to a 3.31. that would explain why my speedometer understates my actual speed. my real speed is 73 when the speedo indicates 65. only a lower rear end gear ratio can do that(or a larger diameter tire/wheel combo, but thats not the case). if people were honest this world would function so much better, all the previous owner had to do was tell the truth and it wouldve saved me 500 on a wild goose chase. ill report back when i run the numbers adn do the actual check this weekend.
