docraymund
Hi! How's your truck now?
Yes same here after sitting for almost 5 months my 2000 expy won't crank. Thought it was the battery (more than 6 years old) but still retains charge. Tightened battery cable wire connectors more and it cranked! Now, problem is it won't run. Am testing fuel pump circuit. At least yours is driveable although you need to pop the hood Everytime. Try testing the starter solenoid under the hood. Good luck!
Yes, it should only have 12 volts on start going to the solenoid. You need to do some wire tracing.
Shift into neutral and try starting. Your problem reminded me of the scene in 'Christine'. Arnie sweet talks it into starting.
