2000 Expedition-1 window doesn't work
NickPap
Marietta, GA
2000 w/ 5.4 L, XLT, 2WD, right front passenger window does not work with either the door switch or the drivers master switch. All other windows work. No sound when the switch is pressed. Suggestions on cause or repair?
Bedrck47
Elizebethtown, PA
Welcome to the forum Most likely a bad window motor Pull the door panel find the connector for the window motor check for voltage at the connector when the switch is pressed if you get voltage then replace the motor assembly
