Hello everyone. I am a new member having some issues with my Expedition. I Bought a high mileage 2001 expedition about a year ago, the price was right. Had to do a few things to it such as replace battery, alternator, and brakes all the way around. It ran fine over the course of the year then suddenly developed a coolant leak from the water jacket on the intake manifold. I removed the manifold and found the aluminum broke at the seal on the passenger side. I bought a new Dorman intake manifold and replaced it. Everything went back together good. Took it out for a test drive and everything seemed fine. Drove it to work (40 miles round trip) and all was good on the drive in. On the way back, however, about half-way home (about 10 miles) the temperature guage jumped right up to the red. It was a hot day so had the air conditioner running, not sure if that had anything to do with it. I pulled over, let it cool off and was able to get it home (with one more stop due to overheating). When I got home I took the radiator out and flushed it out, did a flow test and coolant is flowing freely through the radiator. Put it all back together and took it out for a other test drive. All was good for about 30 minutes and then the temp gauge started inching upwards. I was running the air conditioner for about half the time I was driving (again not sure if that had any bearing on the issue at all). It has a new thermostat that came with the Dorman intake manifold, so that shouldn't be the issue. The only other thing I can think of is water pump, but why would it run normal for 30 minutes (drove about 30 miles or so) before it began overheating. Anyone have any ideas?
